| Suspension setups, shocks, springs, tires, handling. |
#16
NiZan is one of the fastest growing car club in Auckland. They work closely with Advance Import (if you have ever heard of them)
Those ppl are mainly drifters with 200sxs Check out the next car show (is it the nationals)? They should have their own stand there Anyway... I really think we should form a Primera club... This way we could easily get sponsored by different car related shops and workshops. :alien: Peter knows a lot about the Primeras. AFC..? It looks better than what it performs for Primeras, yet it is a completely different stories for turbo cars. I have always wanted to get the header and the whole exhaust done by Peter... but was afraid that the money vs power is not worthwhile.. Would anyone know how much power increase could/would you get from doing the entire exhaust for a Primera? from the extractors to the tip. |
#17
Count me in for a Primera Club. With all the Primera's in NZ it wont take long to get numbers up.
Peter is the man when it comes to Primera's alright. He's been a help with mine also. Very clever guy by the sounds of things.
Current Build.....1/12 Scale Camaro......Almost finished!!! ![]() ![]() View All My Models Here. |
#18
Hmmmmn....a club eh? I guess we could start by asking people to express their interest in a club, where's the best place to do that?.....newspaper ad? radio? carshow? Did you get the AFC coz Pete recommended it or for another reason. I'd really like to know what they did to your airbox (hint )My stock header looks like a pretty good unit performance wise so I'd change other things first. Might be worth your while to compare your exhaust manifold with one from a TE or T4 Primera - The stock one on my T4 is fabricated from flanges and pipes and looks like any 4-2-1- aftermarket header - might be a cheaper option if it all fits together. Be aware that if you overdo exhaust mods you can end up trading low rpm power (most driving time) for hi rpm power (least driving time). Use the forum's search function to view the extensive exhaust discussions that have been. I've just had a look at my Hayne's manual to see the differences in your engine and others. The cam lobe heights make interesting reading as follows: Phase I (1990-June 1993) and Phase II (June 1993-October 1996) SR20de..........37.920 - 38.110mm SR20DE..........38.408 - 38.598mm (like mine - 110kW) Exhaust cam for both.....37.920 - 38.110mm Phase III (October 1996-September 1999) SR20de..........37.433 - 37.623mm (like yours I think) SR20DE..........37.989 - 38.179mm Exhaust cam for both.....37.309 - 37.499mm You can see the early engines had bigger cams. Might be something else to consider in your quest for power. I'm sure Pete will have an opinion on potential of replacing your cams with earlier model cams.
"The cause of liberty becomes a mockery if the price to be paid is the wholesale destruction of those who are to enjoy liberty." -- Mohandas Karamchand Gandhi "They that can give up essential liberty to obtain a little temporary safety deserve neither liberty nor safety." -- Benjamin Franklin "The biggest cause of trouble in the world today is that the stupid people are so sure about things and the intelligent folks are so full of doubts." -- Bertrand Russell |
#19
As for shortening the dampers, if it's done properly by someone who knows what they are doing, it shouldn't make any difference and on a lowered car could possibly extend the life of the damper since they would be less likely to bottom out (bad for dampers). Quote:
I'm going to build another, even more powerful, but it's going to be a while. I need to rebuild my budget and I need a break from car stuff for a little while.There is one guy who is making almost 200 bhp with bolt-ons using the JWT C-series cams and valve springs and a lot of dyno tuning. He has sacrificed low end power for huge high end power. The engine I built (and about 4 or 5 others have as well) has a huge power band and lots of torque.
George Roffe Houston, Texas USA 00 328i 91 SE-R (well modded) 84 944 SCCA ITS race car under construction "I fear all we have done is to awaken a sleeping giant and filled him with a great resolve" -- Admiral Yamamoto, December 7, 1941 |
#20
#21
#22
#24
OK, Lumpy got back to me while I was sleeping.
Here is his contact information: Glenn LUMPY Campbell or Glenn LUMPY Campbell His website is http://www.driftdivision.com Lumpy is a good bloke and knowledgeable about Nissans as well as other makes. He's be happy to help you. Tell him I sent you. :jump:
#25
Hey thanks for that
#26
On the website it says it has a camber kit for the p11 primera. DOes that mean it fits a P11 G20 too? Also I thought the P11 doesn't need a camber kit.....cuz I heard about that it has a multilink suspension from someone.......Also they have front strut braces for the P11...would it fit a 2000 since Luke said that the 2000 manifold is bigger than the 99....Im out!
#27
#28
There is no such thing of "needing" a camber kit or not
For most cars...when you lower them, they will get a serious change in camber angle..usual into the negative side..... Ppl don't like this because their tyres wear out too unevenly With the P11, the camber angle is complete independent to the ride height... my car was sitting on +0.1 camber..and that wasn't too helpful for handling as well i wanted to lower it so the guard is just sitting on the tyre... with positive or zero camber...it is gonna rub REAL badly so yea... that change in the camber angle improved the performance in unit that is not measurable...have hardly been into a understeer situation ever since.....may be only in wet.... the camber kit is only for front...as rear is good as it is at -1.0
Patrick 99 Primera P11 One stripped down Primera
