Old 11-30-2007, 07:24 PM
Zubski's Avatar
Zubski Zubski is offline
Re: WIP Tamiya Mclaren Mp4/4
Looks great so far, keep up the good work.
No problem
Zubski
Old 12-01-2007, 12:59 AM
Shunter's Avatar
Shunter Shunter is offline
Going along nicely. Looking forward to seeing how the paint turned out.
Old 12-01-2007, 01:56 PM
JohnnyFerrari's Avatar
JohnnyFerrari JohnnyFerrari is offline
update...
masked off the red and sprayed the white with two coats it still needs touch ups...
Johnny
Old 12-01-2007, 02:03 PM
stevenoble's Avatar
I would have thought spraying the red first would have created all sorts of problems and the possibility of the white looking 'pink' However it looks ok in your pictures.Which red did you use?
Steve Noble
Old 12-01-2007, 02:42 PM
hey steve,
what i did to not creat a "pink" coat is i sprayed a silver after the red then sprayed the white and tunred out really good... the red i used is called "Red" i think by testors and its enamal
Johnny
Old 12-01-2007, 04:59 PM
Shunter's Avatar
Hi Johnny looks good and you have done well with the non bleeding of the red. One comment, your red is not the fluro red and this may cause issues for you with the red decals when the time comes of not matching?
Old 12-02-2007, 07:00 PM
hey shunter,
what do you mean about the decals? do u mean the back wing decals becuase im not using them i will be spraying the red there..
Johnny
Old 12-02-2007, 08:40 PM
935k3's Avatar
935k3 935k3 is offline
I hate to tell you this but that Red is totally wrong. To properly paint this car you should have painted the entire body and wing end plates white and make it as smooth as possible then paint the red areas with Tamiya Spray TS-36 Flourescent Red. The Marlboro Mclaren Cars were always white and Flourescent Red(Not the red on a pack of Marlboros)
Old 12-03-2007, 02:07 AM
billypee's Avatar
billypee billypee is offline
Send a message via AIM to billypee
Nice work Johnny. Keep up the good work. Don't take offence at being told you have the wrong shade of red/orange... there are more important things to spend your money on when you are 14
I would have recommended that you use white primer and that you paint the red over a completely white body-work... however, your photographs show that your way works too... bravo!
Bill
On the workbench:
Completed WIPs:
Completed Models Gallery:
Old 12-03-2007, 01:57 PM
ohhhh cr@p thanks for telling me now!!! ohh well the red looks fine to me........ i dont have the money to waste in getting "Flourescent Red" so i used what i had . i will have another update soon..
Johnny
Old 12-03-2007, 02:48 PM
Zubski's Avatar
Hey,
I think it looks really good, keep up the good work.
Zubski
Old 12-03-2007, 03:41 PM
update..
i cant really do anything on the kit right now because i need some paint but i took some pictures of the car fitted..
Johnny
Old 12-03-2007, 04:16 PM
i just sprayed the back wing endplates and some other parts red..
Johnny
Old 12-04-2007, 02:48 PM
update i sprayed the wing endplates and puttied the sink holes on the under tray..
if you look at the red in the picture it looks different from the car red but its the same its just not on micro like in the other pictures..
Johnny
Old 12-05-2007, 12:11 PM
davezilla's Avatar
davezilla davezilla is offline
Good job so far.
you might want to wet sand the body with very fine grit sandpaper and/or apply some polishing compound to get rid of that orange peel. In the future you might want to wait longer before masking and doing that 2nd color of paint (enamel takes at least a couple of weeks to fully cure). That way you won't have that dimply effect on the red parts.
