Old 11-20-2007, 02:32 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Re: chevy wont start
Rockauto.com has one for $36.79. This is one part I WOULD NOT go the cheap route on. Either go with a GM part, or a high performance aftermarket.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
Old 11-22-2007, 11:14 AM
young_11_blood's Avatar
young_11_blood young_11_blood is offline
Thanx for the help i will try and get it running after work
Old 01-04-2008, 07:47 PM
sorry havent been by a computer in a while. Got the pump in but still my pressure drops when i turn it over... so i was thinking it could be the oil pressure switch/sensor. My dad bought one a while back but we cant find where it goes ive gone through a couple rebuild books but still nothing. Please anything will help...thanx for reading
Old 01-04-2008, 11:32 PM
Wstrnsky Wstrnsky is offline
I would check the ignition control module. Might be as simple as that . Like it was with my no start issue recently.
95 GMC Sierra X-cab 350 TBI auto 4x4
Old 01-05-2008, 06:09 PM
... we have replaced that and the coil that goes with it... Is their even a oil pressure regulator on a 97????? My oil pressure drops slowly when i go to turn it over so could their be a seal broken??????
Old 01-06-2008, 10:21 AM
Bob B Bob B is offline
Originally Posted by J-Ri
It won't start, but the RPMs went up?
If the oil pressure is 0, the engine won't start (at least on the older ones, can someone confirm that on a '97?). I would check the oil pressure with a screw-in guage to make sure the guage on the dash is accurate, if it is you may have a bad oil pump.
Hi,
The fuel pump runs for 3-4 seconds to have pressure to start it.
It doesn't need oil pressure to start. However to keep running after starting, it will need oil pressure then. Only around 5 lbs should keep it running. If for some reason the oil pressure goes away while running, it will shut off as a safety.
So for no start at all, get away from the oil pressure thoughts.
Bob B
Old 01-06-2008, 04:57 PM
AAAAhhhhhh But thank you for the help... you saved me money but what else could it be????????/
