Old 02-24-2004, 02:10 AM
pewter73 pewter73 is offline
Send a message via AIM to pewter73
Re: thanks
Originally Posted by buffettgirl55
Good to know info about the cuspid 6x9's. I was doing some research about and ebay auction I saw and I thought they seemed too good to be true. Sorry you had to learn the hard way viper!
I am new to the car stereo thing, but have some ideas and I was looking for a little feedback from someone other than the guy at BestBuy. I have a '97 honda accord, stock system that I want to bring to the next level. I'm not into bumpin' down the street, but I want something that sounds clean with no distortion at high volume with a kicky bass. it was suggested that i get a 10' sub with some good 6x9's, run a 4 way amp (2 lines to the rears and 2 lines to the sub). does anyone think this is too much for what I want? will a strong set of 6x9's do the job? I appreciate any suggestions you have! thanks
try audiobahn their great for subs
Old 02-24-2004, 03:48 PM
loismustdie loismustdie is offline
hahahaha..........audiobahn, great subs
the aquabats are seriously the best band in the world
Old 03-09-2004, 02:28 PM
darkpharaoh darkpharaoh is offline
Re: 1400 Watt 6 X 9 speakers
I have 2 12" Rockford hooked to a 800 Watt Performance Technik mono amp, sounds pretty good but it doesn't give me the bass i want. also a rockford capacitor , 4 channel 400 watt sony amp for mids and highs, Pioneer headunit any suggestions....change amp?..change spkrs?...
Old 03-09-2004, 02:46 PM
sr20de4evr's Avatar
sr20de4evr sr20de4evr is offline
Re: Re: 1400 Watt 6 X 9 speakers
Is all of the above an answer?
RF subs....well, depending on the model, they can be useful I guess. They get loud for cheap, as long as you don't care about how the bass sounds then they're a viable option. I've never even heard of Performance Technik, and Sony car audio sucks balls. If you want to upgrade I recommend replacing it all and starting over. The Pioneer head could be a solid base though, probably no need to change that as long as it still works well and has the features you want.
'01 Black Sentra SE
Weapon-R intake, HS header, HKS catback, ES motor mounts, B&M short shifter, Tein coilovers
Alpine 9835, Adire Koda 6.1, Adire Brahma 15, Arc 2100cxl, Linear Power 2.2hv, Cadence ZRS-8
'05 Silver WRX STi
Injen SES Downpipe, HKS Carbon-Ti catback, Cobb Stage 2 Tune, TiC Super Shifter, TiC Klunk Killer, Tein springs, Nitto NT555R Drag Radials
Old 03-09-2004, 09:04 PM
bumpinstang77's Avatar
bumpinstang77 bumpinstang77 is offline
Send a message via AIM to bumpinstang77
Screw all you guys my setup is the best. I got a million watt legacy amp!!!!(well its only 50x2RMS, but its a new way of rating the peak!!!), Two pyramid 12's the give a loud and clean .5 million watts each (oh wait they blew up when I put 100 watts to them) and my lanzar cap gives me all the surge i need for the million watts from my stock battery and 24 AWG power wire!!!!! BEAT THAT SETUP!!!!! BTW is in a inproperly tuned bandpass with more mirrors, neons and chrome then the eye can handle. What Now!!
Old 03-09-2004, 10:47 PM
sr20de4evr's Avatar
awesome man, I bet that hits atleast 180 hyper decibels
you should compete!
'01 Black Sentra SE
'05 Silver WRX STi
Old 03-11-2004, 03:37 PM
Yea I compete in the backyard spl competition and with my magnified mic I hit 150db!!!!
Old 11-02-2005, 10:24 AM
Fusionnoisuf Fusionnoisuf is offline
Amp
I'm a total newbie, was wondering if someone can tell me if this is good for a monoblock:
Max power, 2 ohm 2200w x 1
RMS power, 4 ohm 1200w x 1
Bridged power N/A
Max Power 3000w x 1
Signal-noise-ratio >100dB
THD .05 %
Dimensions, 11 1/2" W x 2 1/2"H x... 12 7/8"
Old 11-02-2005, 10:33 AM
sr20de4evr's Avatar
Unfortunately many of those specs are easy to "fudge" so it's impossible to say. The easiest way to see if it's a good amp is to look at the brand's reputation. You also need to know if the amp will put out the power you want at the impedance you need. That one looks like it will do 1200x1 @ 4ohm and who knows what at 2ohm (max power is useless).
'01 Black Sentra SE
'05 Silver WRX STi
Old 11-02-2005, 11:13 AM
As I said, I'm a total newbie.
The brand is Boss, their rep good or bad??
Old 11-02-2005, 11:35 AM
sr20de4evr's Avatar
definitely bad
check this out, you don't really need to know what you're looking at in these pics, as long as you know what you're looking for. Some of the more important things in an amp design is the number (and quality) of the output transistors (the things lining the sides of the amp) and the number and size of the power supply caps. The transistors are what provide ALL of the power that is delivered to the speaker, they spit out the voltage and supply as much current as is "requested" by the speaker. They're the heart and soul of the amp, the more you have the more current the amp can supply, more current carrying capability means they're under less stress during normal operation, the amp is more reliable, etc. The power supply caps are what provide power to the output transistors in between the pulses of the switched power supply, in essence, the more powerful the amp is the more power supply caps it needs, if it doesn't have enough then they'll run dry and the amp will suck.
Look at these pics, the 1st is a Boss amp rated at 3000 watts, the 2nd is a US Amps rated at 3000 watts. Notice a difference?
Boss
US Amps
While the Boss doesn't look that bad, there is no WAY it can do anywhere NEAR 3000 watts. They do this a lot, the build an amp that can do about 500 watts reliably, they give it enough output voltage where it can do about 1000 watts before clipping (even though it's not clipping, everything in the amp is being stressed to the max and will fail pretty easily), and then they stick a 2000 watt rating on it.
'01 Black Sentra SE
'05 Silver WRX STi
Old 11-02-2005, 11:52 AM
And Boss speakers?
Old 11-02-2005, 03:08 PM
sr20de4evr's Avatar
I wouldn't trust them any more than their amps
'01 Black Sentra SE
'05 Silver WRX STi
Old 11-02-2005, 03:34 PM
Hey,
I've been looking around a bit. How's Pyle Audio?
Went to their site but they have no RMS value on their amps.
Old 11-02-2005, 04:31 PM
sr20de4evr's Avatar
pyle is just as bad as boss
'01 Black Sentra SE
'05 Silver WRX STi
