Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 10-30-2007, 12:38 AM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Re: Performance upgrades
Definitely worth the money, IMO, the UDP is going to give you more of a gain though. As for a CAI, a true CAI or a short ram will do you just fine.
95 Talon TSI AWD
97 Eclipse GST
Old 10-30-2007, 08:56 AM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Cat-back exhaust and a header should give you a little bit more. A bored out throttle body might help a little. You will end up wanting more power and will eventually put a turbo kit on it.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 10-30-2007, 10:46 PM
l_eclipse_l's Avatar
l_eclipse_l l_eclipse_l is offline
Originally Posted by JoeShmoeAltima
l eclipse l, is that the V2 intake? how good is it in comparison against other CAIs, and where does the intake filter end up?
No its not...just a regular AEM. The filter is down in the bumper. I like it and would recommend it, but don't pay more than $100 for it. I got this one on eBay for like $90 shipped.
Originally Posted by UnderEstimate Me
I doubt bolt-ons will get you to 160hp on the 420a. Unless you have some dyno sheets Im calling bs.
I was referring to crank hp. Nobody else is disputing my estimate who knows anything. I myself would be lucky to be around 147-148 crank hp and do not have all the mods I mentioned, so you get no dyno sheet. Unless you have a dyno sheet to prove me wrong or experience with the 420A, call BS on someone elses time.
'92 3000gt SL
Zoom Stage 1 Clutch
Originally Posted by kjewer1
I disagree. Better is better. Bigger is just bigger.
I just made that up, and I like it.
Old 10-31-2007, 12:08 AM
Holset powered 420a
l eclipse l is not to far off. With a few bolt ons the 420a should be putting out around 160bhp. There are to many variables such as: air temp, wear on motor, how hot the motor is, and the dyno to determine how much power you WILL put out with the given mods, but that is the range it should be in.
98 Eclipse GS Turbo
2001 BMW 325i - DD
new2mitsu new2mitsu is offline
i had a 98 avenger with the 420a motor, header, catback ram air, and a 50 shot of nitrous. the nitrous the engine pretty much handled well stock... with the mods, i'd say i was right around 200 hp sprayin, although i have no way of truly knowing, i kno i would run about dead even with a mid ninetys mustang GT 4.6l. and including the nitrous, i probabally had less than a thousand in mods, that's the route i'd go if you're looking for cheap power outta the 420a.
'93 3000gt VR-4
170k, 27k on JDM motor
MBC @ 14.5 psi
Datalogger
Intake
T-Pros Downpipe
Gutted Pre Cats
Mods to come: Upgraded Fuel System and 75 shot of Nitrous, Full Exhaust and hopefully 15Gs
Audio
Sony Deck
Eclipse 6x8 2 ways in the back
Clarion Kevlar cone Component System in the front
2 Alpine Type S 10 inch DVc Subs
1 Audiobahn 10 inch DVC D Jones Series
One 800 Watt Jensen amp
and a soundstream 300 watt 4 ch to the speakers
And still under 4000 lbs w/ me in the car
Old 10-31-2007, 12:18 AM
I wish I would have taken some base hp dyno pulls with my worthless RS before I started putting money into it. I'd like to know how much I'm gaining with the CAI, UDP, ported head with both manifolds matched, exhaust, and a bored TB. I bet I put down about 170 crank, if not a few ponies more. She's definitely got more pull in the higher RPMS than before, not much down low though, probably being cause it's an auto.
95 Talon TSI AWD
97 Eclipse GST
Old 10-31-2007, 10:51 AM
bleedEGLblue's Avatar
bleedEGLblue bleedEGLblue is offline
That would be interesting to see what you can do to a e/t/l start to finish. Get that would be pretty cool to be able to hang up some sheets in the garage to brag to everyone that you freed up that many ponies.
Live From The Great State of Hockey
93 Eagle Talon Tsi
Rebuild TTD:
Ross Racing Pistons(.20 over) - comp 101200's - Head Rebuild Kit - Port/Polish - Big 16g ported Internal WG 34mm - DNP Tubular Exhaust Mani - Megan Racing O2/Outlet - Apexi DP - Walbro 255 - 660cc's - Venom FR - JDM FMIC - Link - Apex'i timer - Short Throw - OEM TB - -6 Fuel Line - FPR - Water/Meth Injection - GM MAF
Previous Mods: GReddy type-rs BOV, 2.5" exhaust, ED Drifter BodyKit, Python security
Old 10-31-2007, 03:20 PM
rickyrickster25's Avatar
rickyrickster25 rickyrickster25 is offline
How much are dyno runs typically? I just started ripping my RS engine apart, and i could easily put it back together stock, if a few people wanted to pitch in a couple bucks or something, i wouldnt mind getting that info for you guys, being as its the direct route im taking with my RS.
...I usually dont take sides, but damn... you got served, lol
97' Eclipse RS 5 Speed 420A
Under The Hood:
Bomz UDP, Custom CAI, NGK Plugs, Mopar Wires
Interior:
Blue Glow Dash Guages & HVAC Controls, Neon Accents, Custom Dash Work\Paint, Alpine Type-R/JL Audio System, Custom Trunk Layout
*GOAL* - Prove Him Wrong
Old 10-31-2007, 04:12 PM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Ah nOObs serving nOObs...
Don't worry I'll be getting mine dynoed next year. There will be no big changes from now til then. I basically did all the bolts on you can do before block rebuild and turbo.
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 11-02-2007, 01:20 AM
theres a place around here that about 100 bux a pull, and i think 250 if you get three
'93 3000gt VR-4
MBC @ 14.5 psi
Datalogger
Intake
T-Pros Downpipe
Gutted Pre Cats
Audio
Sony Deck
Old 11-02-2007, 11:47 AM
Holset powered 420a
Holy shit! $100/pull. When I dynoed mine it was $90/3 pulls with a/f. I Think most places charge about $75 for 3 pulls.
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 11-02-2007, 01:12 PM
Yeah I think the last time I was around a dyno it was like $30 a pull or $75-80 for 3.
95 Talon TSI AWD
97 Eclipse GST
Old 11-02-2007, 01:34 PM
david-b's Avatar
Dave is THAT guy
I'm going to get mine dynoed next year, early spring. Then will hit up the track and put down some times and fine tune her up. Then we can all see with all bolt-ons, (minus turbo) exactly how much the 420a motor makes. Obviously as stated above many variables come into play, but we'll get a ball park figure.
Still taking donations for dyno day too. Paypal accepted.
75 Monte Carlo
Old 11-02-2007, 03:48 PM
My bad, maybe thats an All Wheel Dyno...
'93 3000gt VR-4
MBC @ 14.5 psi
Datalogger
Intake
T-Pros Downpipe
Gutted Pre Cats
Audio
Sony Deck
Old 11-04-2007, 03:10 PM
Just to give the 420A a little more pride, i took down my friends Dodge Stratus the other day which is pushing over 200 hp, plus he has a chip and a CAI, he has over 60hp on me and i took him down by almost a car length...
Under The Hood:
Interior:
