Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 10-28-2007, 03:59 AM
kjewer1 kjewer1 is offline
AF - Advisor
Re: Fu*king intercooler pipes...
It's an ooooold skool DSMer trick, now you know.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 10-28-2007, 11:29 PM
Black99GST's Avatar
Black99GST Black99GST is offline
Send a message via AIM to Black99GST
haha! Found these on Ebay. let me know what you think, if this would be a good clamp, i have looked all over town, and had NO luck! so back to good 'ol ebay!
Old 10-29-2007, 02:54 AM
AF - Advisor
Those look like typical tbolt clamps.
Kevin Jewer
Old 10-29-2007, 09:49 AM
Black99GST's Avatar
yeah, but they cost $.99 each, and are $2.49 each to ship... i was also looking at the OBX ones, because they come in a set of 10 and thats exactly how many i need... for like $25 shipped... haha just heard bad stuff about OBX, but i think their clamps will be fine?? right?
Old 10-29-2007, 10:28 AM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
That pretty much what I got. They work fine.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 10-30-2007, 12:57 AM
AF - Advisor
Those clamps are 2.49 at NAPA IIRC, so he is probably swapping the cost of the part and the shipping to try to be a clever ebayer. Not impressed, but they should work just as well.
Kevin Jewer
Old 11-01-2007, 03:29 PM
airFS airFS is offline
Have you considered one of these??
http://www.slowboyracing.com/estore/...at=1055&page=1
96' Talon tsi AWD
Mods: greddy upper and lower intercooler pipes _ greddy type rs bov _ K&N intake _ 3" turbo back exhaust _ ngk spark plugs & wires _ garrett T-28 turbo _ greddy oil catch tank
Old 11-01-2007, 03:48 PM
Holset powered 420a
That seems a bit unnecessary. A good set of couplers and t-bolt clamps should be more than enough to hold the pressure in, if not then weld beads around the end. I really dont think anyone would possible have a good use for it.
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 11-01-2007, 09:29 PM
rock0134 rock0134 is offline
Send a message via AIM to rock0134 Send a message via Yahoo to rock0134
I got a 2 foot section of black 2.5" id heavy duty hose shit from napa and made my own couplers. Then I mostly used two basic hose clamps per connection side (4 per connection) and tighten the shit out of them. I used to have pipes blowing off or out of their socket a lot for a while then I redid it all and made sure every connection had the pipes touching inside the coupler and clamped really good. Never had one blow off since then...
T bolt clamps are definately the way to go but they are a little more expensive
SOLD
'97 GSX
EvoIII 16g, FMIC shortroute piping, FIC 850's, DSMLink V2.5, 3" turboback, mbc, Walbro 190 rewired, autometer boost gauge, Tokico shocks/springs -2", Motegi MR7 18" hyper black wheels
'05 blacked out f150 FX4
Old 11-02-2007, 10:32 PM
AF - Advisor
The straps are very useful on cars running high boost and aluminum piping. By the time you get the tbolts tight enough to keep the couplers on at say 45 psi, you've crushed your expensive aluminum pipes. Just like you should never use one fastener to both locate and clamp an important part (example, head stunds clamp the head down, dowel pins locate the head on the block(prevent side to side movement)), many people prefer to use couplers/clamps to only do the pressure sealing, and use boost straps for locating the parts. There is no reason to avoid doing it this way other than cost and additional welding (if you can't do it yourself). It just isn't really necessary for people running low boost and steel pipes that allow you to crank down on the tbolts.
Kevin Jewer
Old 11-03-2007, 09:54 AM
Holset powered 420a
So why would you want to use aluminum intercooler pipe. It may be lighter but if you cant tighted the clamps enough and have to use this other shit then it doesn't even seem worth the gains of lighter intercooler pipe.
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 11-03-2007, 11:04 AM
Blackcrow64's Avatar
Blackcrow64 Blackcrow64 is offline
Cause they're shiny...
-Brian
  • 92 Firebird sold
  • 97 Talon TSI AWD sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 06 Cadillac STS4 AWD sold
  • 03 Corvette Z06 sold
  • 14 Silverado 1500
  • 26 Equinox RS
Old 11-03-2007, 05:03 PM
Holset powered 420a
So is chromed out metal!
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 11-03-2007, 07:11 PM
AF - Advisor
The average guy may not want to deal with aluminum IC pipes, but a car that's going ona diet can't avoid them for long.
The EVO's stock IC pipes are aluminum BTW.
Kevin Jewer
Old 11-03-2007, 07:22 PM
___Brandon ___Brandon is offline
60?
Tonight its 34 here in MI and I'm jumping on the Harley to go for a cruise!
