#16
Re: '97 Taurus GL 85,000 miles. P0305
Back home and I have my Taurus back! |
#17
well after a few days of no probs. I was coming home from work last night and the cel came agine and guess what it was shooting out ? You got it P0305 and ideas now. ? Jim
#18
Well, you may want to check the compression on your cylinders and make sure that comes back fine. The plug from cylinder #5 didn't happen to be abnormally clean, did it?
-Rod |
#19
I don't think a burnt valve would get better with a new coil for a few days, then go bad again.
I'd suspect instead that maybe the connector to the coil primary is loose or you have a loose plug wire. Pull lightly on the wires for the coil primary and see if the connector just pops off. If so, you probably found your problem. Also, inspect the coil ground wire to make sure it is clean and secure. Then inspect the terminals in the coil connector to make sure that they are all clean, straight, and not pushed into the connector housing. A compression check should indicate if the problem is possibly a burnt valve. -Rod |
#21
