#16
Re: 2000 Inner Tie Rod - My Experience
Wintonboy,
You changed 3 tie rods and didn't do all 4? I sure would have done all 4 - in fact, I have a single inner that needs replacement and I'm debating if I should do the inner/outer on that side, both inners, or all 4 since every time you replace one, you have to get an alignment. $60, that had to be for the labor and alignment, right? You supplied the parts? Regards Tom |
#17
Me too went to Autozone and their tools are simply the wrong ones:
1) Correct hex size but merely a 16" deep well - will not pass over larger diameter of the actual ball joint. 2) Slotted fabricated socket: would have worked I think but the hext size was too big. So basically, they don't carry the prropriate tool. Auto Supermarket said they have one but now I'm skeptical. I thought I was going to do this job and now I'm fussing around with the tool. The thought of making a big open end wrench work sounds real good. |
#19
Mr. Creosote,
I realy don't understand your name, but anyway. Ford I believe on all of mine, starts out with a continuous hex shaped ball joint end on the inner tie rod. When I replaced one, the aftermarket, I think like you said, is rounded around the ball joint, and just the far end is hex shaped. If one could fashion or get a crow foot or like tool for the size of the inner tie rod hex, that would work. I couldn't wait to get the loaner tool and wasn't sure if it would even work after all the bad chatter on the loaners, so I found a large enough adjustable to take it off, as I have done on other vehicles. Then to make my life easier for putting on and taking off the new one with the rounded end later, I very carefully ground down the hax from ~1-5/16" (33-34mm) to fit my 1-1/4" wrench. The rack will have to be turned all the way out to do this. The driver side is easier because there are more openings underneath it to get to it with a wrench,so you may be able to get to it better that way, whereas on the rt side has the exhaust pipes, etc. to only allow you to get to it from the wheel well. I was also removing the sway bar links, so I took them off and worked on the tie rod with them gone. BIG help. . |
#20
Tripletdaddy are you saying that if you (I) have a 1 5/16" box wrench then it will work to undo the OEM part? Does this wrench need to be slim? I've got a big adjustable wrench which is about 5/16" thick. Will this do?
Piper
----------- 2000 windstar 3.8 2010 honda pilot touring Muskoka Canada |
#21
For me, a long deepwell will NOT work - you would have to have something like a crowsfoot if you want to do it in that manner.
After I heard that someone else did it with a wrench, I said screw the specialty tools and successfully did mine with the 1-5/16 open end wrench. The only issue is that you don't have a lot of room to turn the nut so you have to turn the wrench over after each pull. There is just barely enough room to do this. The wrench does NOT have to be slim. If you want to get medieval on it, you might be able to use a ball peen hammer to dent in the floorboard right where the wrench motion is stopped. I remember one side was easier than the other. The hardest part is getting the boot back on the rack housing and clamping it. Also, when you pull the boot off, there is a balance tube which connects to the other boot. If you are carefull, you will not pull it out of the other boot. If you do, then you have to get under the other side to get the tube back in that boot before you slide your boot on. |
#22
As Mr. Creosote said, there is room to get at it with a wide wrench. I don't have a 1-5/16" wrench so I had to use a large adjustable to get it off. I think Mr C used a combo wrench. That size gets really long. An adjustable tends not to be so long. I often will crack it with the larger wrench first and then use the shortest adjustable. There is an aluminum rivet tapped into a hole on the side of the hex nut to keep it from loosening. I always thought getting it out whole with a sharp tool and side cutting pliers, it would be easier to crack it loose. Not sure that is true, but all the after markets I've seen use a hardened roll pin, which I found to be a pita to install, that must be removed next time. On the pass side, I had to turn the wheel as far as it could go so that I could get my wrench on it as there wasn't room to get to it from below. The driver's side has all sorts of room to get at it from below. I think I covered some of this in my previous post. Oh, and I don't think you can use a box wrench, only an open end, because you can't slip the box over the rod and get to the nut, the body is in the way.
#23
would this tool work??
http://cgi.ebay.ca/COMBINATION-INNER...QQcmdZViewItem
#24
I took a look at it. It has possibilities. Plews I believe is a good name. Assuming the tube is long enough, it should work, though they don't have their facts right as you need the 1-5/16" for some fwd fords not just Chrysler. The smaller size probably fits the smaller fwd. I recall my escort being smaller. If you change a lot of inner tie rods than the money might be well spent. If you get it, let me know how well it works. I saw in the picture some sort of opening on the side of the socket end by the part number that I don't know what it does.
#25
That is the tool that I mentioned when I started this thread. It is the one I used to complete the repair and it worked well, I rented it from autozone. It won't fit the autozone tie rod but fit a tie rod I got at another store. Re-read the first post for more details.
#26
Jacked up the van, pulled the wheel, removed tie rod end, removed inner tie rod boot. NOW, on the inner tie rod there was a pin (more like a rivet) through the threaded area that needs to be removed. I simply tapped a chisel carefully under the lip of the rivet then pried the pin up and out.
Was this pin through the head of the inner rod? Please elaborate. |
#27
Yes, it is a pin through the head that screws onto the rack... to keep it from unscrewing I guess.
#28
10-4 I look for it when it goes back up--I am having an issue with my ford..
http://www.automotiveforums.com/vbul...d.php?t=891827 Simular to yours --diff model--any thoughts |
#29
I'm wondering about applying enough torque to disassemble as well as assemble the inner tie rod to the rack. Is there a flat or some sort of space to grip the portion of the rack that the inner tie rod attaches to? I'd hate to torque the inner to the 65 ft-lbs (or whatever it needs) and cause some sort or rotary damage on the rack.
Any info?? Oh, btw, I got a 1-5/16" tie rod socket of ebay that looks like it'll work on the moog I've bought. Don't know, but hope, it'll work on the oem part I have to remove. TIA Piper
