Old 10-27-2007, 10:55 AM
FrodoGT's Avatar
FrodoGT FrodoGT is offline
Re: brake question
No to 1, Yes to 2. Dropping those rotors from any normal height is not going to hurt them. They could hold the weight of the car and be fine. Its a good idea to check behind though.
Cheap, Fast, Reliable..Pick two
Current project:
Rio Red 91 hatch.
A6/Z6 build, Hondata S300, Tokico illumina/Ground Control.
"I'd rather run 12's on steelies than 15's on rotas."
Old 10-27-2007, 01:48 PM
Nick Gautreau's Avatar
Nick Gautreau Nick Gautreau is offline
Send a message via MSN to Nick Gautreau Send a message via Yahoo to Nick Gautreau
Re: brake question
Easy enough. If theres something (rust, grease, road debris, etc...) between the rotor and the wheel hub, it could put your wheel at an angle when you bolt it on and cause it to vibrate.
The brakes on my car...
Yes those are ACTUALY the brakes on my car.
No the thing ain't street legal.
Yes I do drive it around.
Originally Posted by Dr0pZ0n3
I just think it's funny to pull up to a redlight in a beaten 4dr against some oldie in his "muscle" car... rev the lil tiny snowblower motor against his loud ass V8, then leave him sitting there when the light turns green...
1990 Honda Civic DX - Getting custom!! Needs battery
I need parts for my car. Please contact me via PM if you have anything to get rid of
Old 10-27-2007, 02:12 PM
FrodoGT's Avatar
Re: brake question
Those look like artifacts dug up from some indian burial mound dude..damn. They dont even have a distinct shape anymore. Especially the caliper.
Current project:
Rio Red 91 hatch.
Old 10-27-2007, 09:29 PM
Christ Christ is offline
Send a message via AIM to Christ Send a message via Yahoo to Christ
Re: brake question
EDIT... those are the "lack" of brakes on your car... no pads, no brakes bro... do you stop it w/ the e-brake or something?
I did that for awhile when one of my lines broke on my old azz sunbird... stopped w/ the e-brake and downshifting... made for a fun time when someone stopped quick in front of you.
Old 10-27-2007, 10:11 PM
Re: brake question
yup... use ebrake
i just crank it as hard as i can... oddly doesn't lock... its like ABS on handbrakes. (stops fast too, so I know their not worn)
Old 10-27-2007, 10:17 PM
Re: brake question
rofl... it's pry stretched or something.. so you may be reaching the end of the e-brake travel before the brakes can lock.. but hey, if it works, use it :P
Old 10-27-2007, 10:22 PM
Re: brake question
no I can feel the tension and the handle only goes about 3/4 of the travel it's supposed to have.
I checked the rear pads the other day... they were about half an inch thick, but the drum is totaly shot... rusted to hell (rust actualy ADDED thickness to the drum.)
Old 10-27-2007, 10:27 PM
Re: brake question
that might be why they won't lock too.. the rust might be breaking off and "rolling" between the pads and the drums.
Old 10-28-2007, 12:40 AM
Re: brake question
that might be. Although that doesn't explain the Xtreme stoping power it has! It literaly push me into the belt and tilts my head forward... that's how strong it is!
Old 10-28-2007, 10:19 AM
Re: brake question
again, could be that the rust is causing enough friction to stop you at a glance, but not enough to lock. BTW, nice sig
Old 10-28-2007, 12:10 PM
FrodoGT's Avatar
Re: brake question
well at least something works. My crx rears were so bad that I would CRANK on the damn thing and nothing would even happen..then all of a sudden I would start hearing the left rear lock. And it STILL didnt slow me down by more than about 3mph. My hatch rears are much better, I know because I blew the right front brake line about a month ago.
Current project:
Rio Red 91 hatch.
Old 10-29-2007, 01:51 AM
Re: brake question
I have bad rear bushings... the trailing arm bushings.. so the rear end clicks sometimes if I jack on the brakes real hard... I have urethane inserts for them tho.
Old 10-30-2007, 08:11 PM
pbrizzle86 pbrizzle86 is offline
Send a message via AIM to pbrizzle86
Re: brake question
i checked all my ball joints and bushings and everything seems to be in order. i had some stainless steel brake lines waiting to go on so i put them on and found i was missing the little copper washers on the passenger side brake line. the shaking has been reduced quite a bit but is still there. i know there is no air in those lines cause we bleed the lines like crazy with a machine and by hand. the alignment is all in spec so im now turning my attention to my rims. i think i may have a bent rim or two seeing i got these rims second hand i dont know what they have been through but there is a considerable amount of curb rash on those babies. but thanks for all the sugestions. Paul
