Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 10-18-2007, 11:35 PM
PeteA216's Avatar
PeteA216 PeteA216 is offline
Send a message via AIM to PeteA216
Re: TBI Throttle Position V.S. Power Output
Cool. How'd it work out?
Old 10-19-2007, 06:02 AM
CD Smalley CD Smalley is offline
Much better than the static adjustment of the JET unit.
CD
1991 W41 #142
1989 Caprice 9C1
1997 C1500
1997 Bonnie SE
1998 Olds 98 LS
Recently updated: http://forums.b-body.org
Old 10-19-2007, 01:02 PM
PeteA216's Avatar
So wait a minute, let me get this straight... you put that TBI in place of an E4ME carburetor? How did the computer control the injectors?
Old 10-19-2007, 04:20 PM
DANZIGS DANZIGS is offline
Greygoose006, it is a limiter in a way. Your stock fuel pump for a TBI motor is putting out about 20 psi maybe a little more. Your stock fuel pressure regulator in the TBI unit is non adjustable and keeps it anywhere from 8 to 10 psi on average. The aftermarket adjustable units allow you to adjust the output. The motor responds a lot better with 12 to 14 psi. I can't speak from personal experience since I have not done this mod yet, but Hotrod magazine had an article on this using a TBI 350 in a truck.
Old 10-19-2007, 05:59 PM
Noooooo Nooooo Noooo.... The 89 was already TBI. I just modified it.
CD
1991 W41 #142
1989 Caprice 9C1
1997 C1500
1997 Bonnie SE
1998 Olds 98 LS
Old 10-20-2007, 11:57 PM
PeteA216's Avatar
Ohhh, Okay I kinda figured. Did it make any difference in how the engine performed? I could nab a junkyard TBI and experiment with it, but I don't want to waste my time if it doesn't make a difference.
Old 10-21-2007, 11:20 AM
With all of the TBI mods done it was much free revving. It pulls harder clear through to the shift points. It used to fall on its face up close to the shift points at WOT.
A replacement fuel pump will help quite a bit. I used a pump for 94-96 LT1 power b-body to be able to get the pressure up and keep it there. It was too much strain on a TBI pump. I did have to adjust the pressure down quite a bit though!!
CD
1991 W41 #142
1989 Caprice 9C1
1997 C1500
1997 Bonnie SE
1998 Olds 98 LS
