Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 09-27-2007, 11:50 AM
TalonEclipseMixGsx's Avatar
TalonEclipseMixGsx TalonEclipseMixGsx is offline
Re: firing order on Linked '99
Oh that little spacer pissed me off more than ever when I dropped it. It ended up being wedged in one of those little cracks on the lower part of the intake mani. I'm not sure how important they are, but I wouldn't want to run without it permanently. http://www.slowboyracing.com/estore/...at=2226&page=1 As you can see they're pretty cheap. I'm not sure about all injectors, but my 550's came with caps on them that I needed to take off. I wouldn't think that they would even fit on there with the caps unless you had to force it. But yeah taking the fuel rail off is about a 10 minute job. I would just go ahead and do it to make sure.
98 Eclipse GSX-EVO3 16G, BC 272's,ETS FMIC and short route piping,TRE Stage 2 tranny, ACT 2100, Walbro 190lph,550cc jectors,SAFC NEO,GM MAFT, AEM UEGO wideband,ported SBR Exhaust Manifold,O2 Dump,EBay Intake,3" megan downpipe and catback exhaust,TurboXS boost controller,HKS BOV,Ebay Short Shifter,Boost Gauge,Symbroski shift kit & shift cable bushings, RRE catch can
94 Talon 1.8L-SOLD
02 Civic EX- Daily driver (staying stock)
Black99GST's Avatar
Black99GST Black99GST is offline
Send a message via AIM to Black99GST
ok, checked it... no caps on the injectors, none that i could see anyway... wtf? i compaired them to my factory ones, and they look about the same only my new ones are way bigger... i have fuel in the rail, but not in the combustion chamber... my problem is the injectors... what can i do?
Old 09-27-2007, 12:08 PM
steviek's Avatar
steviek steviek is offline
you put the injector clips back on right?
I lost one of the spacers once and just bought a new one from mitsubishi and ran it for a little while with only 2 its no big deal. After that I have always just glued them to the head so they stay on it when I take off the rail its one less thing to worry about.
FP 18g turbo e3 o2 & mani, 3" exhaust, , 7 bolt, wiseco/eagle, walbro 255hp re-wired, Aeromotive FPR, FIC 1150cc, injen intake, greddy RS, aem wideband, turbo xs mbc, act 2600 clutch sprung 6 puck, BC 272's, dsmlink v2.5, ETS FMIC, Devils Own, JMF SMIM.
18 Inch chrome rims
In closet AEM Fuel Rail, SS Lines,
1997 TSI AWD
Diamonds Are 4Ever
12.7 @ 107
http://i83.photobucket.com/albums/j2...y/DSC00461.jpg
Old 09-27-2007, 12:11 PM
Not to insult your intelligence, but did you take the injector all the way out and look at both sides? Was there anything stuck in the fuel rail, or anything stuck in the part that the injector goes into? Did all of them have the correct wires plugged into the injector? Maybe if you reinstalled the old injectors that worked, and it fired up you'd be able to definately narrow it down to the injectors.
94 Talon 1.8L-SOLD
Old 09-27-2007, 12:13 PM
defiancy's Avatar
defiancy defiancy is offline
Stay classy San Diego
When my ECU went out, I had spark and fuel. Car just cranked and cranked but never started.
Not saying that is the problem. But did you try swapping your old ECU back in and cranking it up? (Also remember to change the plug ordeR)
1991 GSX 2.3 Stroker
Old 09-27-2007, 09:01 PM
Black99GST's Avatar
yeah, i'm going to swap the computer back right now... thanks guys! i'll keep you posted...
Old 09-27-2007, 10:58 PM
Black99GST's Avatar
fired right up with the stock '99 computer and the 950's in it... ran like shit, so i shut it back off... guess my eprom is bad... anyone got one for sale (2g)? fucking hell i just bought the bitch to!!!
Old 09-28-2007, 07:45 AM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
When they blow I think its just a couple capacitors that usually do it so it might be repairable.
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 09-28-2007, 10:47 AM
Black99GST's Avatar
how would i look into getting it repaired?
Old 09-28-2007, 10:53 AM
defiancy's Avatar
I'm not quite sure about this. You would need to take it to somewhere that repaired electrical components. If you open up the ECU and take a look at the components, the capacitors looke like small round batteries. One may have busted open (My guess).
I know there are some internet shops that will fix them for you, but I think because of the market they may over charge alot.
http://simon.chi.il.us/ECU/ECURepair.html
If you look at the pictures this guy has. You can see what the caps look like, and what they look like when they leak (bottom picture) Although this is for a 90-93 ECU it's very similar.
Old 09-28-2007, 11:03 AM
Black99GST's Avatar
i dont think i have any blown caps... i'll get some good ass pics and post them up here... the ECU works, its just fucked up... when i turn the key to the on position, it makes this "BUZZ" sound and you can feel vibrations inside the car... then i try to start, and my fuel pressure drops, and the car sputters, then just cranks... then i put it back to the on position, and it goes back to vibrating and loud buzzing! i dont know, but its pissing me off beyond belief!
Old 09-28-2007, 11:20 AM
defiancy's Avatar
Yeah, I'll take a look if you get them posted, I used to do this kinda work in the military, so if it's a visual thing I may be able to spot it. But gripes and problems like this may no always be visual. And perhaps it may be a matter of one of the components in the ECU being fried.
If I can't see the damage it sounds like you got the shit end of the stick if you ask me. Where did you buy this from?
Old 10-01-2007, 11:56 AM
Black99GST's Avatar
update time! ok so i sent the computer to a friend of mine who owns uprev engine management solutions here in Austin, Tx... and he found a few problems with the ECU and fixed them, well, i brought it home, and no luck again, it sounds like the relays are clicking on and off like MAD (tons and TONS of clicking... almost buzzing) then when i try to start , it just cranks and cranks... so... i'm looking for another eprom ecu... i'll get pics up though... maybe it'll be worth it... how do i post up HUGE pics?
Old 10-01-2007, 12:25 PM
Black99GST's Avatar
they came out REALLY SHITY! But...
