| Search | Car Forums | Gallery | Articles | Helper | Quality Dog Food | IgorSushko.com | Corporate |
| Latest | 0 Rplys |
Show Printable Version | Email this Page |
#16 | |
![]() Join Date: Sep 2007
Re: Need help with 89 mazda rx7 rotary engine.
the spark plugs were replaced in 2002 or 2003 just before the car was parked.
#17 | ||
EEeesh... Hmmm be carefull and take it slow thats all I can say my friend.
#18 | |
hey guys. took this car of mine to a dealership to have a professional to work on it. first thing they did was do a compression test on it. 3 out of the four chambers, cylinders or whatever read about 5.3 compression when the best possible is 7.9 or somthing like that. the 4th chamber read 0(zero) compression. will replacing the rotary seals repair my problem or am i screwed?
#19 | ||
boost in, apex seals out
there aren't 4 chambers in a 2 rotor engine, there are 6 (3 per rotor). you want to take your car to a rotary specialist, let us know where you live so we can find you someone.
RX-7 TII |
#20 | |
Grangeville idaho zip 83530, gettin ready to move to missouri for 6 months car will be left here in idaho
#21 | |
Sounds like it could be a few things actually. If the engine is not idling correctly and you are having to press the accelerator to have it run then it could be the BAC(Bypass Air Control)valve located right below the intake manifold next to the top fuel rail. Disconnect the harness from that and try to crank the car. Could also be bad TPS sensor or MAF(mass airflow) sensor giving bad readouts. Had that issue before.
