Old 09-21-2007, 06:23 PM
cyberkid's Avatar
cyberkid cyberkid is offline
Re: Food dehydrator speed up curing times?
I remember seeing a post here saying that the max temp that should be used is 90 something F. I don't recall the exact number.
Could some one who knows the 'facts' post them up? I mean, the max temp to be used.
Please read the following linked articals before posting a question.
Once you have and still have questions, try to post your questions clearly.
This will make a lot of people's blood pressure drop back to normal, including mine.
NEW TO THE AF MODELLING FORUM? PLEASE READ THIS FIRST
AF Car Modeling Tutorial, How-To and Product Review Depository
AF Car Modeling Frequently Asked Questions [FAQ] - * Look here first! * ver2.0
And finally,I wish you all happy modeling
Old 09-21-2007, 06:52 PM
mj71 mj71 is offline
My experience is strictly limited to Tamiya styrene, but I've been good up to 110F. Beyond that, when removed the styrene is definitely getting softer. I usually keep it at 105 in case the thermostat has some slop in its sensing. I'd certainly recommend taking some sprue or a chunk of whatever material you're using and test a temperature first.
On a side note, be very careful putting spray cans in to warm them up. I've read where getting the can warm can help flow, but I've had several invert their bottom "lids" at 110F. I now don't go above 95 for spray cans.
Old 09-22-2007, 09:49 AM
cyberkid's Avatar
One word: DON'T!
metal itself conducts heat thus making a one source 110F environment turn into a 110 x n source environment. If something goes wrong, ie: temp sensors haywire, heat knob or button gets accidentaly nudged etc etc... you could end up with a grenade in your oven.
What I find works well and is safe is to run handable temp water over the can or let the can sit in the sink filled with handable temp water... What I mean with handable temp is that you are able to hold your hand in or under the water without it being too hot for you to stand. I heat my cans for 5-10 minutes.
Old 10-18-2007, 10:06 PM
Sixx Sixx is offline
I have great luck with an Excalibur branded dehydrator. Very large internal volume. It would fit a 15" 1/12 car without any problem. They're pricey, but when you're not using them for modeling, they do a great job at making great snack food!
http://www.excaliburdehydrator.com/5...gular-prod.htm
I wouldn't want to eat at your house
just kiddin' man, my ol' lady would kill me if her dried apples tasted like paint
