Old 09-12-2007, 06:42 PM
00accord44's Avatar
00accord44 00accord44 is offline
High on Potenuse
Send a message via AIM to 00accord44 Send a message via MSN to 00accord44 Send a message via Yahoo to 00accord44
Re: 91 cx with 1.6?
There's a million things to investigate in trying to build up a honda powerplant especially with B series motors. You gotta look through the stickies in the Honda forums all the info and links you'll need are there.
Maybe do a search within the sticky threads for 'chassis' and see what's highlighted
ECNATSISER AL AVIV
Old 09-12-2007, 07:23 PM
Tony's Avatar
Tony Tony is offline
TLD Member #1
Send a message via AIM to Tony
Re: 91 cx with 1.6?
Most of your engine questions answered here!
Look through the FAQ first, it explains alot. That post is from the FAQ and will fill you in on most of the common engine swaps. Most engine swaps don't require any chassis modification more complicated than taking a BFH and making a dent in a frame rail and buying a mount kit.
Also, Honda engine codes are usually found on a small flat area on the front of the block on the tranny side of the engine(it will be on the left side of the exhaust manifold by where the trannsmission mounts on most engines...don't know for sure on the K-series, or some of the V6 engines)
VTEC-Honda's Variable Timing, much like what every other import maker has..each one has a different name, to tired to name them. VTEC in short: low rpms=a less aggressive cam lobe for better fuel economy, and probably other reasons, then once you hit a certain rpm, it kicks the rockers over to a more aggressive cam lobe giving you better top end.
VTECH-They make phones...not motors, or anything to do with motors.
Do some more reading and become friendly with the search function here and your favorite search engine. Lots and lots of good reading on the net, just gotta find it(its not hard)
Tony
91 Civic Sedan DX - Stock 287k Miles
Old 09-12-2007, 07:32 PM
Tony's Avatar
TLD Member #1
Re: 91 cx with 1.6?
Oh yea, forgot to list some examples of what you will see for an engine code. Yours will most likely say D16Z6, also stock for the 4gs would be the D15B2. Ofcourse you also have the B16, B18, B18A, etc. etc. You can find a list of engine codes relatively easy. The first letter indicates what series the engine is: D-series is usually SOHC motors(with exceptions), B-Series are usually the DOHC motors. D & B Series usually come from a Civic and Integra and usually easy to switch between the 2 motors. The F-series usually comes from the Accords and is usually a SOHC motor, while the H-series came from the Preludes and is DOHC...also usually easy to switch between the motors...see a pattern? The K-series is the newer engines from the Civic and RSX's.
There are a ton more series, Wikipedia is also your friend. I said usually a lot while explaining them, because there are exceptions,which I'm not going into.
Like BLU Civic has said twice and I have said once already, read the FAQ. Click the links, enjoy.
Tony
Old 09-12-2007, 11:15 PM
FrodoGT's Avatar
FrodoGT FrodoGT is offline
Re: 91 cx with 1.6?
A b16 requires no chassis mods, just bolt on stuff like mounts and shift linkages and axles..you will need a rubber mallet to pound a small dent in one specific spot ot clear the alternator but that is ALL. and btw if your talking about the k20 from the 02 si, then that is 160hp. The rsx has a 212 (with new sae ratings)hp k20a3, and the 06+ has the 197hp k20z3.
Cheap, Fast, Reliable..Pick two
Current project:
Rio Red 91 hatch.
A6/Z6 build, Hondata S300, Tokico illumina/Ground Control.
"I'd rather run 12's on steelies than 15's on rotas."
Old 09-15-2007, 10:42 AM
cx1.6 cx1.6 is offline
Re: 91 cx with 1.6?
thanks you guys were more help then blucivic
Old 09-15-2007, 10:53 AM
Tony's Avatar
TLD Member #1
Re: 91 cx with 1.6?
Adrian can be very helpful, just some of these older members get annoyed when people don't either use Search or check the FAQ first. Just gotta do some research on your own next time first, then ask.
But don't worry, I do shit like that sometimes before I search.
Tony
Old 09-15-2007, 11:00 AM
Ajax Cole Ajax Cole is offline
Banned
Re: 91 cx with 1.6?
Check out www.ajaxcole.com for a free preview of the upcoming manuscript The Enforcer's Guide to NASCAR Like Driving Skills, a book showing how NASCAR Racing and everyday driving coincide!!
Old 09-15-2007, 01:34 PM
Christ Christ is offline
Send a message via AIM to Christ Send a message via Yahoo to Christ
Re: 91 cx with 1.6?
Originally Posted by cx1.6
so a 1.6 in my hatch is a b16?
it is a SOHC motor........so i dont have vtech i know that much
Actually, if you had a D16Z6 (92-95 civic Si) it would be a Vtec motor... and the only things that someone would need to change it to that.. A wiring addition, and some extra oil lines, (if it was just the head swapped)... and a ECU swap or flash.
So you might wanna search before you post things like this... you're obviously not an authority on what is and what isn't VTEC... so take the advice of the mod's and elders here... use the search function.
Old 09-15-2007, 05:52 PM
BLU CIVIC's Avatar
BLU CIVIC BLU CIVIC is offline
調整器
Send a message via MSN to BLU CIVIC Send a message via Yahoo to BLU CIVIC
Re: 91 cx with 1.6?
i point him twice to where this information in the FAQ thread and i wasn't helpful sorry i didn't go to his house and click on the link for him
Originally Posted by BLU CIVIC
Need to look thru this first
and if you can pick that motor up for $200...do it
RSX...eh...it's ok and it's Vtec
and for all your other questions
*CLICK ME*
The name's Adrian
1990 Civic HB Si - 265.7whp/223tq @9.2psi. Tuned on NepTune by J.Mills
1991 Civic Sedan DX - 296.3whp/230tq @1bar. Tuned on NepTune by J.Mills
1991 Civic Sedan DX - 185.8whp/139tq. Tuned on NepTune by J.Mills
2006 G35 Coupe 6MT - Stock
2011 CR-Z - Stock
Old 09-16-2007, 01:49 AM
Tony's Avatar
TLD Member #1
Re: 91 cx with 1.6?
Shame on you!
Tony
Old 09-18-2007, 09:33 PM
thefooshmeister thefooshmeister is offline
Send a message via AIM to thefooshmeister
Re: 91 cx with 1.6?
we become a$$holes when ppl start sayin hondas suck and things like VTECH
adrian i can always count on your avatar for some eye candy lol
98 Jetta GLX VR6-vroom vroom!!
91 CRX Si-R..busted..
Old 09-19-2007, 02:35 PM
viper-blue's Avatar
viper-blue viper-blue is offline
Re: 91 cx with 1.6?
I can add my two cents about the CX model civic. It must be exclusively a Canadian car as I see them here in Canada all the time. I was a little bewildered cause most American forums make no mention of them at all. They came stock with a 1.5 and are pretty much a mirror image inside and out of the DX.
89 crx SI - spoiler, custom viper blue paint job, Z6 just completed, stock 14's with a 3 inch drop, sidemarkers, and the stereo
"my crx is like my woman: don't like anyone touching her, or driving her but me!"
Old 09-19-2007, 03:02 PM
BLU CIVIC's Avatar
調整器
Re: 91 cx with 1.6?
i thought the CX was the US STD that came with the D15b2
The name's Adrian
2011 CR-Z - Stock
Old 09-20-2007, 12:28 AM
Re: 91 cx with 1.6?
those tricky canadians..
Old 09-20-2007, 07:01 PM
viper-blue's Avatar
Re: 91 cx with 1.6?
Most of my knowledge has been gained on these forums and I was a little bewildered the first time I saw a 4th gen with a CX on the back of it. There are all kinds of 4th gen model CX civics driving around Canada. I'm not sure what the deal is with them. They just have the 70 horse or whatever Dx engine in them.
