Go Back   Automotive Forums Car Chat > Oldsmobile > Aurora
Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 03-18-2008, 10:31 PM
back2life's Avatar
back2life back2life is offline
Re: Water pump help plz
nooo! its not magic just some good stuff! spray the mating surface and let sit a few minutes and it should break free. if not soak again and tap with a mallet or hammer carefully. also a trick for holding gaskets to the mounting area is to spray with light coat of spray adhesive and stick gaskets to it. works on alot a places to keep them still while assembling items.
  #17
Old 03-19-2008, 03:39 PM
nicks84 nicks84 is offline
Hmmm, well I guess I have only one question. Does this can spray when it is upsided down ? I will find out when I buy some today but I only ask because when I used the cheap pentrating lube, it didnt. And as you might know, there is not a whole lot of room to manuever. I couldnt see the pump just comes off. It seemed to be a part of the block itself, or attached to a peice of the block that is WAY too much hassel to remove. And by anychance do you know, assuming the water pump is a clock, what time will there be mating surfaces at ? I only ask because I cant really see down there very well (bad angle and not enough room), some sort of idea of how many mating surfaces actually contact each other, and where they might be located woudl help alot.
  #18
Old 03-19-2008, 07:52 PM
back2life's Avatar
if u think you will be using it often, then you can get the gallon and it comes with a spray bottle. as for the aerosol it does not spray well upside down. some have the straw on them to shoot in precise spots. as for the mating surfaces i really dont remember. u have to make sure your trying to turn it the right way also. get the new one out and that should give you an idea of the way to turn amd or mount it.
  #19
Old 03-26-2008, 11:02 PM
KJH KJH is offline
I used an 18 inch breaker bar on mine with a hefty sized piece of pipe to increase the leverage beyond that and I am certain my arms would've given out long before any permanent damage occured to the engine but, to no avail.
A good mechanic and friend of mine with nerves of steel used a torch to cut away pieces of the water pump until it finally broke free. Good luck
  #20
Old 03-27-2008, 10:07 PM
SWEET, Thanks a million Back2life, and everyone else that suggested anything! That PB Blaster is some BAD A** Stuff. It did take a day and a whole bottle. I saturated it on every 1/2 hr and kept prying on it. I used a prybar and a BFH.
I was really about to give up for the day and buy another can for tommorrow and continue till it finally gave. I decided to try one more time. It was then I thought I broke the tabs to the pump or stripped out tool, or just broke something. To my suprise, I looked down and it was out ! I was Sooooo happy. Thanks another mill. I was actually begining to just hand it back to her and tell her I can't help her. And form the other posts I read, this issue can cost alot of money. And that, she dont have . And of course, It was after I got the pump off, that I found out where that 4 inch diam O-ring goes (the one that comes with the pump). It goes behind he pump.
The car does not leak anymore (YAY). I did not refil it back with coolant yet. I wanted to make sure it did not leak anymore. And it does NOT. I do need to do a flush n fill though, there seemed to be alot of gunk in there. White foamy stuff and some minor corrosion. I will do that later this weekend. She needs her car and is very thankful to all your suggestions as well.
Ummm, I got a handful of pictures taken. I havnt really looked at them yet (on the pc) so I dont know how they turned out. Assuming all the pics came out decent, maybe someone else is interested in seeing them on post with pics, instructing them the process?
  #21
Old 03-27-2008, 10:47 PM
Wow thats funny.
I think the breaker bar with a pipe may have prevented me almost breaking my arm tryin to turn that suker. lol, I'm really suprised I didint think of that . . . Well, I guess the important thing is that I got it off. Ill keep that in mind for next time.
  #22
Old 03-28-2008, 08:26 AM
back2life's Avatar
good job nicks! anyway make sure to bleed out the cooling system after your done. also if you want you can refill with one of the prestone brand lifetime coolants if you want instead of that old dexcool bull@#$%. every car i get with it in it i take it out.
  #23
Old 05-22-2008, 10:00 PM
WILL9390 WILL9390 is offline
I have a 1997 olds Aurora an the engine runs hot only in the afternoon when the outside temperature is 84 to 96 degrees and above. In the mornings when the temperature is 64 to 78 degrees and below the engine runs normal temperature from 160 to 200 degrees. I drive105 Miles to work one way and the temperature stays normal and is with my AC on all the way. But when I leave work in the afternoon with the outside temperature 84 degrees and above I get about 25 miles down the hwy and my enine runs hot and the water boils out the water reservoir bottle. I replace the radiator, water reservoir bottle cap, water pump,upper and lower radiator hoses, thermostat and water pump pulley belt. I don't know what else to do. It only get hot when the outside temperature is 84 degrees and above. Can anyone help me.
  #24
Old 05-22-2008, 10:24 PM
back2life's Avatar
check your cooling fans for operation,if not working then thats the culprit. they should also be running when the ac is on.
  #25
Old 06-18-2008, 08:18 PM
My 1997 Olds Aurora is overheating. I have changed everthing in the cooling system at least I think so unless their is something that i am missing and the engine is still running hot when the outside temperature is 90 degrees and higher. I only be 26 miles into my destination and the temprature starts rising this only happens in the afternoon. In the mornings when the temperature is 65 to 80 degrees the engine runs normal and I drives 105 miles one way to work. In the afternoon on the awy back home wit the temperature 90 degrees and above 25 miles into my destination the engine temperature the engine overheats. Can you help me? Thanks
  #26
Old 06-29-2008, 01:47 PM
brody1 brody1 is offline
Have you tried turning the tool counter-clockwise!!! it should come out with ease.
  #27
Old 06-29-2008, 02:45 PM
maxwedge maxwedge is offline
A990 racer
Ok guys we are jumping back and forth with different issues/posters here. This is 3 months old and we need to start a new thread for new issues, thanks.
Closed Thread
