Old 08-22-2007, 01:00 AM
sportracer02's Avatar
Re: GB 60 red years: F40 LM 1:16
Hi,
that is great !!!
Fantastic scratchbuilding !!
Micha
Old 08-22-2007, 03:23 AM
Scuderia. Scuderia. is offline
Ambitious project, I am very interested to see what you can do. The scratch building so far looks great
Old 09-09-2007, 08:51 AM
Martin S's Avatar
Martin S Martin S is offline
The kit brake discs looked decent, but there were no ventilation channels so I decided to make new ones.
The calipers are also rediculous for such a big scale kit. They are not visible from the outside !
This means that when you look through the spokes of the wheel there will only be a brake disc, no caliper.
But more on the calipers later. Now on to the front discs:
First I made 4 discs out of styrene by just rough-shaping by a knife, then drilled a hole through all four discs.
Then I bolted them together with an M2 bolt and nut which I put in a drill machine and sanded them circular.
Then I marked the ventilation holes (pic 1).
I drilled a pilot hole and inserted a small pin to keep all four discs exactly positioned (pic2).
And then there was a whole lot of drilling.. but the nice thing is you get 4 identical discs.
This also means any mistake is aslo visible on all four
In pic 4 you can se the intermediate piece, the ventilation channels, of the discs.
The finished result, also with a center piece:
Latest progress:
Ferrari F40 LM Fujimi 1/16 and Porsche 959 Fujimi 1/16
Finished:
1940 Ford pickup and Lotus Super Twelve
Old 09-10-2007, 04:14 AM
AllAlone.Gz's Avatar
AllAlone.Gz AllAlone.Gz is offline
WOW! Your scratchbuilding skills are amazing! You are one of many with hands of a surgeon for custom model work! Keep us updated!
'99 Honda Civic Hatchback-R.I.P May 04, 2010
NikonEquipped.
Flickr.com/photos/oneohnine27
OneOhNine27*
Old 09-10-2007, 01:24 PM
dj_woodster dj_woodster is offline
i was in ore reading through the scratch build radiator and front struts but those disc brakes are amazing nice work
Old 09-11-2007, 01:31 AM
klutz_100's Avatar
Super!
Old 11-25-2007, 07:48 AM
Martin S's Avatar
Long time, no update!
But this weekend I found some motivation to carry on with the LM...
Last update covered the discs. The kit calipers were useless, so I had to cast some new ones.
The kit rear calipers are actually pretty decent, but they are only the inner half of the caliper, and are also cast together with the parking brake caliper.
So I decided to cast a few pieces of the useful half of the caliper.
I used modeling clay as a mould and cast the calipers in plaster. Poor mans resin ;o)
But works really well, dires fast and is very easy to work with afterwards.
The first tries looks a little rough but they are very easy to sand to a nice finish.
The caliper halves were cut out to fit around the disc:
The rim interfered with tha caliper so I had to sand the rim on the inside.
Next problem was that the disc was way to far on the inside of the rim.
This I had to correct by drilling out the disc so that the center part of the rim actually goes thhrough the disc:
Then a distance ring was made to be able to attach the disc to the front hub:
The finished result:
Latest progress:
Finished:
Old 11-25-2007, 07:55 AM
360spider's Avatar
Wow, nice scratchbuilding! Great job on the brakes. Looking forward to updates.
Old 11-25-2007, 01:43 PM
klutz_100's Avatar
Killer work, Martin!
I can't wait to see what else you have up your sleeve for this build
Old 03-13-2008, 11:27 AM
Studio-VS's Avatar
Studio-VS Studio-VS is offline
Send a message via MSN to Studio-VS
I love this kind of work, I am fan of modifications. Congratulations! Fantastic.
Old 03-13-2008, 12:37 PM
godfather23's Avatar
godfather23 godfather23 is offline
Impressive scratch-building. Your technique is something worth a copy when in need. Keep it up!
Robert
Recently finished Projects:
Porsche 911 Carrera RS 3.0
Current Projects:
Old 03-14-2008, 03:58 AM
mrawl's Avatar
mrawl mrawl is offline
Damn, nicely done! Plaster eh? Who would have thought...
Old 05-28-2008, 11:48 AM
Martin S's Avatar
I'm still working on the F40, although the progress is a bit slow.
Right now I'm working on the engine.In the F40 the engine is quite visible when you open the engine bay so I wanted to make it quite detailed.
Fujimi has made a beautiful engine as always in their 1/16 models.
Added some fuel pressure regulators and a fuel rail:
The intake manifold:
Most work of all was spent on the turbos.
Fujimi has made a big mistake in the turbo instalation on this kit. The exhausts go from the manifold into what looks like the compressor part of the turbo. The exhausts then exit the same turbine radially and continue into the intercooler ! (upper left pic) Ooops..
What is supposed to look like the exhaust turbine has no inlet at all, but just an outlet axially to the exhaust system (upper right pic)...
This had to be corrected:
The final installation position:
The wastegate Y-pipe was detailed with a spring-loaded expansion joint:
And how the powerplant sits in the chassi:
Latest progress:
Finished:
Old 05-28-2008, 04:03 PM
jano11 jano11 is offline
Excellent progress, the engine looks great!
Old 05-28-2008, 04:10 PM
gionc's Avatar
gionc gionc is offline
Authorized Vendor
Great job martin also on the engine, one of my preferred powerplant, you'll feel a lot of fun detailing it.
gio
