Old 08-25-2002, 10:17 AM
454Casull 454Casull is offline
I would like for us to have individual electronically-acutuated rotary valves, in fact. Seems like the best of both worlds.
Some things are impossible, people say. Yet after these things happen, the very same people say that it was inevitable.
Old 08-25-2002, 04:58 PM
YellowMaranello's Avatar
YellowMaranello YellowMaranello is offline
Send a message via AIM to YellowMaranello
You could make some and make millions, that is, if internal combustion engines stick around...
Old 08-25-2002, 06:11 PM
BeEfCaKe BeEfCaKe is offline
Going back to the mucho-cylinder engine... i was thinking, how big of a gas tank would i need to travel say... 100miles or wahtever? Also, as the car begin to carry more gas, its also increasing weight, both through the fuel itself, and also the tank inwhich to contain it...
obviously, if such an engine were really made, it probably won't be a street car, but drag/race-only type...
Old 08-27-2002, 11:45 AM
ivymike1031 ivymike1031 is offline
Send a message via AIM to ivymike1031 Send a message via Yahoo to ivymike1031
Originally posted by Heep
I've thought about that as well. But consider engines of the exact same size...a 6 liter 8 cylinder, or a 6 liter 60 cylinder. I assume the 60 would have a FAR higher redline, but that the 8 would have FAR more torque. Just what I'm assuming, anyway. Input?
The '60 would have a spaghetti noodle for a crankshaft - it wouldn't last.
Also, as you break the displacement up amongst more and more cylinders, you increase the surface area. Sooner or later, you'll be sending nearly all of your fuel energy into the cooling jackets instead of the crankshaft.
Come on fhqwhgads. I see you jockin' me. Tryin' to play like... you know me...
Old 08-27-2002, 07:55 PM
Maybe that's why cylinders are cylinders and not rectangular prisms.
Old 08-29-2002, 04:42 PM
Porsche's Avatar
Porsche Porsche is offline
Pretty much amazing
Send a message via MSN to Porsche
LMAO! Some old lego cars had some square ones.
So going the opposite way, why don't we have 1 Cylinder 6 liter engines? Or more practically, as in old steam ships, the 3 Cylinder (I know cars aren't steam powered, so it would just be a 3 Cylinder rather than the triple Expansion three cylinder.) My frined's dad said he saw a bus with a 3 Cylinder, massive, is this right? I thought buses were all 6, 8 and 10's.
ec437 on grammar;
Originally Posted by ec437
I'd've
Originally Posted by 2strokebloke
Any car built by "Dr. Technology" is probably not worth $5000
Old 08-29-2002, 07:29 PM
I'm sure that there are several thousand single cylinder 6L engines in the world.
Most buses that I'm familiar with use straight-six diesel engines (although there are some I4's around too, and probably some others that don't come to mind).
For most applications, steady delivery of torque is desired. Having multiple cylinders (3 or more) makes this goal easier to achieve. It is also common to want smooth, vibration-free operation, and engines with 6 or more cylinders have a leg up on the competition in this department. Packaging concerns also play - a single cylinder engine is squat, while an inline six is long and slender.
The largest-displacement engine that I have direct experience with was a natural gas fired 22L/cyl V18 (396L total).
Old 08-29-2002, 08:39 PM
Oh, you saw it? I had it in my toy train set. I wonder where it is now...
Old 08-30-2002, 11:45 AM
Shaw Shaw is offline
Coates - CSRV Rotary Valve System
I saw your post on the CSRV rotary valve system and thought you should know that Porsche has already stepped up to the plate and has bought a license for the system. You may be able to take one of the new models for test drive in the near future
Old 09-01-2002, 05:14 AM
Thunda Downunda Thunda Downunda is offline
Originally posted by ivymike1031
For most applications, steady delivery of torque is desired. Having multiple cylinders (3 or more) makes this goal easier to achieve .. The largest-displacement engine that I have direct experience with was a natural gas fired 22L/cyl V18 (396L total).
.. and then there's the famous Honda 125cc 5cyl GP race-bike engine from the 60's
Old 09-01-2002, 07:07 PM
replicant_008's Avatar
replicant_008 replicant_008 is offline
Torque vs Power...
More cylinders equals more complexity, more moving parts and the associated reliability and friction losses...
In some cases, particularly with smaller displacement engines the gains from the additional cylinders is offset by this issue. I'm thinking particularly of the Mazda I4 1800cc vs the Mazda 1800cc V6 (the twin cam 4 was a much better engine than the little 6) and the Altezza (Lexus IS200) which is available with either a I4 or and I6. The I4 is a torquier and more powerful engine but less smooth than the 6.
Incidentally...
The Southward Car Museum at Paraparaumu in New Zealand has a replica of a Chitty Chitty Bang Bang supercharged Mercedes 28/95 cars (built in 1914) with 6 cylinders. The engine was based on a Zeppelin aero engine and displaced 23 litres! That's the entire displacement of a Commodore V6 PER CYLINDER with 162mm bore and a 202mm stroke or in inches 6.377 inch bore and nearly 8 inch stroke... yikes!
Old 01-07-2005, 02:27 PM
Evil Result Evil Result is offline
Send a message via AIM to Evil Result
hehe awesome
http://www.bigbikeriders.com/48cyl.htm
I disregard my perceived image in the persuit of knowledge.
Old 01-07-2005, 09:26 PM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
Re: too many cylinders?
Most large ocean-going (non-military) ships these days use huge internal combustion engines where each cylinder has a bore and stroke of 3 to 4 feet or more. They burn bunker sea oil, which is something like diesel that didn't quite make the grade.
They turn at about 60 rpm, with very heavy flywheels. They are very efficient in producing huge torque numbers over a narrow rev range while burning a very low-grade fuel.
Compare that to something like an older Honda CB 400 motorcycle where each of the 4 cylinders displaced just 100 CC. The ship engine is more efficient for its application.
The question here is what is the measure of efficiency?
Cost of operation?
Cost of manufacture?
Power output?
Fuel economy?
Obviously, there is no one best answer, it depends on application.
Old 01-08-2005, 09:14 PM
383PhoenixAm's Avatar
383PhoenixAm 383PhoenixAm is offline
Send a message via AIM to 383PhoenixAm Send a message via MSN to 383PhoenixAm
I'm going to go out on a limb and actually respond to the question here.
In my opinion, as there are more cylinders, I don't think that they would eventually become insignificant, rather than just less significant. Saying that all things are equal, and that such an engine was tuned perfectly, no cylinders should really be unable to account for any power. An engine as such-with 50 or 60 cylinders, could be experimented with in such a way that the power could become tremendous thanks to the individual cylinders. Two or more cylinders could be firing at once, amplifying the thrust effect on the crankshaft, or the cylinders could be configured to fire at close radius degree proximities to eachother, producing en ever-active force on the crankshaft. Any way this would work could be made to produce more power, no matter the number of cylinders. The thing is that after a while, after all the parts and stress on them from such an amount of power, the engine would become extremely impractical. It would waste fuel like crazy, produce far too much emissions, and be plain out impractical to use on anything. This is just a theory, though.
Old 01-10-2005, 05:13 PM
Adamsindrey Adamsindrey is offline
Send a message via MSN to Adamsindrey
One thign that limits the amount of cylinders you cna have is your crank shaft. a reason manufacturers dont make straight engines like straight 8s or anything more than a 6 is because the longer you have the crankshaft the more it winds up as each cylinder goes through power stroke. a 60 cylinder engine wouldn't have a crank strong enough to harness the power succesfully.
4 cylinders are optimum in my oppinion, 3 cylinders are not as smooth and cant haul round bigger cars, 6 is propably second to 4 but pretty much anything you can do with 6 a 4s not far behind, and an 8! god dont get me started on the modern american car with its v8! bad performance+bad economy=bad engine
