Go Back   Automotive Forums Car Chat > Chevrolet > Cavalier > Performance
Performance Anything you ever wanted to know about boosting the performance of your Cavalier.
Old 08-29-2007, 11:10 AM
cavaliercrazy cavaliercrazy is offline
Send a message via AIM to cavaliercrazy
Re: Beafore I Boost
but why would he pick a small turbo like a 14b and run 15 psi? Even then it STILL might be enough power to blow his engine. and how did you come up with those hp numbers for the 2 different turboes?
Thanks for the informative links. I know how to read comp maps but, I'll still check em out.
But do you know what I mean... if he compares the flow rate of his engine, looks at some compressor maps, and matches up a turbo thats a good size for what he wants, then there should be no way he could run that much boost without problems...
2004 turbocharged Cavalier
3" exhaust, injectors, Aeromotive FPR, FMIC, AEM wideband, BFG drag radials, Custom Co2 IC sprayer, stiffer upper/lower motor mounts, lightweight pulleys, GM reflash, 10lbs of boost.
Old 08-29-2007, 01:11 PM
Schister66's Avatar
Schister66 Schister66 is offline
AF -Advisor
Send a message via AIM to Schister66 Send a message via MSN to Schister66
Re: Beafore I Boost
Ok to start...
Why run a 14b at 15psi?? I'm not saying its a good idea or that i'm going to, it was simply a basis for comparison. I'm familiar with the flow rate of that turbo and it seems to be a particularly common one in lower dollar setups. There are benefits to using smaller turbos. Inevitably they spool faster and produce more torque through the lower rpms and midrange. Having a fast, streetable car isn't all about the peak power numbers. I dont drive my car from 7-9k rpm all the time...i need some mid.
The power that a 14b would not be enough to blow an engine unless the tuner was completely inept. One of my close friends had a 14b on his D series setup (1.6L SOHC VTEC) and ran it on 11psi daily. He had a built motor and before swapping it in lieu of the stock D, he decided to blow the stocker up. He ran 28psi on the 14b (well above the efficieny) on a tune for 11psi(.8bar). The engine actually lasted an entire weekend and it wasn't even tuned for it!! If you Cavalier guys are concerned with blowing an engine (2.2L no less) w/ a tiny little 14b at 15psi (1.1bar), then GM needs to seriously rethink their "engineering" department because that is just plain crappy.
The way i came up w/ those horsepower numbers is simple. I've been around turbo Hondas for about 4 years now. I have seen countless setups and know the approximate power they're capable of making. Also, unlike most people, i've taken the time to sit down and discuss various topics w/ my mentor, Mac Trapp who is a mechanical engineer specializing in fluid dynamics (aka how liquids and gasses move). He worked for Garrett/ Honeywell for 8 years before opening his own business, STC, where he builds custom turbos for any type of use be it road race, drag, HPDE, etc.... I have also read compressor maps and learned how it all works...for the most part.
To answer your final question "if he matches a turbo to his engine properly, can he run 15psi without blowing it?" to be honest, i dont know. There are simply too many variables. It depends on a few things. It depends on the size of the turbo (lb/min flow rating at given pressure ratio), the engine used, the strength of said engine, how aggressive the tune is, what fuel is used, how much timing is added, and the tuners ability to properly tune a turbo engine safely.
Having said all of that, it is anyone's guess whether or not his engine can withstand 15psi without knowing all of those variables. Basing this on something i understand more, my own setup, we'll continue.
If i were to run 15 psi on my setup (seeing as i had a 3bar map sensor which i dont) i would be on the fence w/ 92 octane. It could be done, but i would be hesitant to drive it hard daily like i do now. With my current setup, i would be making ~380-395whp at 15psi given my IATs didnt rise much. That is a lot of power to put through a stock 1.8L; however, it has not only been done, but surpassed. The highest horsepower stock B series is around the 600whp range. That's with a completely stock OEM honda longblock. The car was tuned on C16 race gas w/ a T3/67 at 21psi on Neptune IIRC. There are countless engines like that on Honda-tech where the owners, generally people who are testing things or simply dont care, push their engines to the breaking point. I know that the highest i can recall is a 692whp/480wtq @ 32psi on a GT3582r on an S2000. It was bone stock w/ something like 34,000 on the odometer. That engine is stout. Also, if you didnt know about the F22c, it is a 2.2L w/ 11:1 compression!
The moral of this novel is that nothing is based on PSI and what you think the limit may be, may not actually be the limit. Dont be fooled by other people's ignorant banter on the internet because the truth is, only about .1% of the stuff you hear is going to be correct.
2015 DGM STi - 2006 SGM STi - 1999 Built/boosted GSR
Old 08-29-2007, 01:13 PM
Schister66's Avatar
AF -Advisor
Re: Beafore I Boost
also, if you THINK you know how to read compressor maps, you wouldn't have asked this question. You should keep reading and keep learning. It took me about 1.5 years to really know and understand what everything meant on a compressor map and how to apply them to my useage. If you have any questions of want other great links, just let me know!
That goes for everyone!
Old 08-30-2007, 12:08 AM
Re: Beafore I Boost
First off...I am so sorry for completly jacking this guys original thread, we are way off topic. But maybe through this little..."discussion" he will learn a thing or two...
I am not trying to be a dick, but do you own a Cavalier? The reason I ask is because to get to this specific forum not only do you have to click Chevrolet..., but also Cavalier... Yet the car in your sig is a honda...???
Anyways, ... I know about turboes being streetable... I probably have more power in the lower rpm's than you...
And for a stock s2000 making 600+ hp... I have to call no way on stock rods and pistons...maybe using the stock block... but if all your using is the block then it's not really "Stock" anymore is it? But I will be honest. I don't know anything about that... but even if someone did... Who Cares? that has nothing to do with this subject. Gm took a regular Ecotec (cavalier engine) and made over 1000hp with it... big deal... I didn't do it.
I don't have a fluid dynamics engineer handy to mentor me about this stuff, but I'm no expert... I just know a little about turboing Cavaliers... more specifically the eco.
"["if he matches a turbo to his engine properly, can he run 15psi without blowing it?" to be honest, i dont know.]"
no. he can't. that engine was not the greatest thing to come from GM... not made for boost... not gonna be pretty.
like forest gump once said. "that is all I have to say about that."
and it is understood that what is most import is CFM or lb/min not psi or boost... I get it. I understand.
I'm now offically done stealing this guys thread and hopefully I"ll try to give him some freindly advise from one turbocharged cavalier owner to another. It is up to him whether or not to believe it.
later on
Old 08-30-2007, 01:25 AM
Dr.Mambo666's Avatar
Dr.Mambo666 Dr.Mambo666 is offline
Send a message via Yahoo to Dr.Mambo666
Re: Beafore I Boost
well then that actually helped me out alot i dont plan on boosting my car until i can get more of an understanding on how they work and what will work best with my car.So in your so called"jacking of my thread" u actually helped along with Schister66.And yeah i kinda knew it wasnt the PSi that killed engine it was the power made wich actually makes alot of sense when u brake it down. I dont have one of those mentors but i do have a friend that has some knowledge with turbo systems(although hes a wrx fan).I think i do a little reaserch on the lb/min on some turbos(do you know what it would be for the T3/T4 i head thats a good turbo) see if my friend can help me with the comp. maps and take a look at the links then try to match the best 1 for my engine stock for now seeing as i just put a new engine in it. So thanks again guys. And i guess GM didnt make the best engine for my car for boosting but the 4T40E tranny can hold its own up to about 500hp so i hear.
2000 Cavalier 2.2L(2200)
16.62 1/4 mile @ 82 MPH God damn thats fast
http://www.cardomain.com/ride/2535716
Old 08-30-2007, 02:33 AM
Schister66's Avatar
AF -Advisor
Re: Beafore I Boost
Well i'm glad my little geek rant helped. If you want some help picking a turbo, just let me know your goals. Be very detailed!! Most people want a certain hp number, but forget that it can be attained many different ways and with a variety of powerbands. Let me know what kind of range you want, a peak power you'd like to hit and a realistic budget. I'll find you something that will work.
In exchange for that, you need to find out what the MAF sensor is rated for
Old 08-30-2007, 03:28 AM
Re: Beafore I Boost
ok i think ill start actuall lookin around a bit when i have a day off i'm a workaholic but im glad that there r ppl here that really know what they r talking about that can actually help ill keep in touch through this thread or ill pm u which ever 1. Right now im not certian as 2 how much whp i want (new kid on the way and its my only car till i get a beater) but when i start looking ill have some number to toss at ya.Thanks again
Old 08-30-2007, 04:44 AM
Re: Beafore I Boost
My budget im looking to hit for a comlete setup is about $2000-$2500 which ill get from my taxes if not more. A range i want from just a turbo is maybe 180-230 whp which i think is possible. If can get more outta a stock 2.2 then im happy. I found a .63 A/R T3/T4 Hybrid Turbocharger
Compressor wheel Trim - 50
Turbine Housing A/R - .63
Max Flow - 635 CFM
Max Psi-30lbs of boost
Which will work very well with my carBut i dont remeber where i found it i just need a blow off valve,waste gate,intercooler,turbo manifold,oil feed+return lines all the brackets and shit. If only i could find 1 website that would have all of this i would be happy. Ne ideas on a good web page?Or ne ideas on the turbo?
Old 08-30-2007, 11:45 AM
Schister66's Avatar
AF -Advisor
Re: Beafore I Boost
by the specs you listed, that's an Ebay turbo and therefore, not something you want to buy. Any journal bearing T3/T04 is going to hit a wall after 24 psi rather than the BS numbers they tell you.
For your power goal, i would highly suggest the T3 Super 60. Its not a hybrid turbo, but for your goals, a hybrid is going to simply be too large. With the Super 60, you'll get full boost fast and meet your goals easily
Old 09-03-2007, 09:51 PM
Lefix's Avatar
Lefix Lefix is offline
Send a message via MSN to Lefix
Re: Beafore I Boost
Hmm.. Just to answer your question, this is a list of things you will need to buy if you're gonna piece yourself a turbo kit which most likely you will be doing cuz you dont have an Ecotec..
I believe you have the 2200 right? since its not a z24...
You'll need to buy:
-A turbo of your choice-get a turbonetics or garret, no ebay! i have a turbonetics T3/T4 Internally Gated Turbo
-Exhaust manifold-this you gotta get from ebay, theres this guy who makes turbo exhaust manifolds for us cavy's and sunfires and sell them on ebay, the seller's name is happythoughts47, i bought mine from him
-A Bov of your choice-i have a HKS SSQV BOV-$250
-2" to 2.5" Charge Piping, either Aluminum, mild steel or stainless steel... Get them from ebay if you want aluminum and its cheap, if you want steel its gonna be expensive...
-2.5" to 3" FULL Exhaust from downpipe.. Buy a High Flow cat if you have emission, if not, just leave it out..
-Oil Feed and return if you have an oil cooled turbo..
-a small size intercooler from ebay is gonna be good enough
-32lb to 42lb injectors should be good size for you..
-1-Step Colder spark plugs-i bought NGK 1-step colder spark plugs
-Injector clips or harnesses for the injectors..
-Wideband of your choice-im gonna get an innovate wideband kit
-Boost gauge and oil pressure gauge-i got mine from ebay from glowshift
-HPTuner-$650
Thats pretty much it...
Its gonna cost you have $2500-3000 all together...
My CarDomain
Boost coming soon...
Old 09-04-2007, 03:04 AM
Re: Beafore I Boost
yeah i was also thinking with going with the super 60 but now tha u meantion it i think i will
Old 09-04-2007, 12:18 PM
Schister66's Avatar
AF -Advisor
Re: Beafore I Boost
you could save a lot of money from the setup that Lefix has listed, but that gives you a good idea of what you need....
