Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 08-23-2007, 11:42 AM
BigCity BigCity is offline
Re: High Erratic Idle
Hello,
I had similar high idling problems. After replacing the IMG and still experiencing high idle I replaced the o rings on the fuel injectors. $20 for the O-ring kit and a couple of hours under the hood.
Old 08-23-2007, 02:04 PM
trooperbc's Avatar
trooperbc trooperbc is offline
Originally Posted by BigCity
Hello,
that's a good tip. what led you to do that?
//bc
1992 trooper 3.2L v6 sohc automatic...as is
i love a good intermittent electrical challenge. . .especially when it's someone else's.
Old 08-25-2007, 01:26 AM
Jdm914 Jdm914 is offline
I did the injector o-rings when I replaced the intake gaskets. Thanks for the suggestion!
I think I might have found the problem with the idle. It looks like there might be a considerable air leak at the input butterfly shaft in the common chamber. I will need to remove the intake manifold and inspect!
Old 09-02-2007, 01:20 PM
I read on this board about spraying carb cleaner around the manifold to check for leaks. I did the same for my injectors and RPMs went up on one injector. This was after I took my Rodeo to a new Hyundai dealer in town who displays an "Isuzu Repair" sign. Anyway, they told me they would replace one of the injectors and the gaskets for $800! Needless to say I did it myself.
I am suprised at how easily grit and dirt can accumulate around those injectors. No wonder they eventually leak.
Old 09-03-2007, 10:42 PM
H2odrx H2odrx is offline
how are the grounds on the tranny and engine?
