#16
Re: vr-4 transmission...
gas milage isn't an issue. i was just wondering what everyone here thought in their opinions. this taller fifth gear i didn't know about though.
i was just wondering if by luck i ever came by one, would it be worth it to put on.
i fix things that aren't broken |
#17
its a simple bolt on upgrade. it replaces the stock 5th gear. they make 3 sizes: 8%, 16%, 25% but the latter requires machining of the shift fork so its not really bolt-on. the 16% taller 5th gear will reduce rpms in 5th gear by 16%. its as simple as that. and it will also give you a theoretically higher top speed...of course, you'll need the extra power to reach that speed. www.teamrip.com sells them. just email and ask about em. i have one in my trans. love it. definitely worth the $300, and much cheaper and more cost effective than the $2,000 you'll spend getting an AWD 6 spd trans to work in a FWD car.
93 3000GT base K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2 coming soon: adj. cam gears | bi-xenon HID retrofit |
#19
i'm not against it by any means.
i was just saying i didn't know that it was an option until yesterday. 300 isn't a bad price. thanks.
