Old 08-06-2007, 09:15 PM
Huney1 Huney1 is offline
Re: Starting Problem--please Help
mass air flow sensor, sable, taurus, 3.0l, ohv
01-03 $196.62 $ 75.00 YOUR COST $147.46 plus shiping?
"If you need to buy a new one then you can get it at wholesale by going here." Hmmmm . . . . $147.46 on line and my main man at Advance Auto Parts told me it is $130.00 in stock and if not they get them overnight no additional charge. I don't get a discount either. F Y I . . .
Old 08-07-2007, 12:27 AM
leshan leshan is offline
Thank you guys. This problem just happened within this tank of gas. It's not for my usual gas station. I happend out of gas, so I stop by the small old SHELL gas station. I always pump shell, chevron, QT. I noticed another problem, after the first time of the problem, I changed the fuel filter. When I pull out the fuel line from the filter, there was not that much fuel spin out as it used to be. Especially from the output side of the filter, feel like no pressure. Since I just bought a 2006 Malibu, the recent two months, I only drive it once a week and less than 10 miles. Everytime I start the car when it was cold, it will crank about 4-5 seconds then got ignition. If hot after driving, it only crank about 1-2 seconds.
Old 08-07-2007, 12:35 AM
The parts which BigFordPartsStore have are genuine ford parts? Motorcraft?
How about this place?
www.rockauto.com
Old 08-07-2007, 08:29 PM
Gary1234 Gary1234 is offline
I have a wagon ... I cut a hole under the back seat to replace the fuel pump.
I don't know if this method is possible on a sedan but it's worth a look.
Old 08-07-2007, 09:02 PM
You are so cool. I can not do that.
Old 08-07-2007, 09:13 PM
"I have my car specially wired up so that if someone tries to steal it the fuel pump shuts off." Sounds good to me, but personally I'll take the Budweiser Trunk Monkey theft prevention and vehicle retrieval system. http://www.youtube.com/watch?v=Ee3L9BQQ4Gs
Old 08-16-2007, 07:06 AM
Mediarocker543's Avatar
Mediarocker543 Mediarocker543 is offline
Send a message via ICQ to Mediarocker543
Originally Posted by leshan
98 taurus se 155k. These days are hot(90F more). My taurus got a start problem. After driving then parking for about 20 minutes under sunshine, I tried to start my car again, sometimes I can not start it. When I turned the key, it cranked, but won't get ignition. Even got start, the RPM was only 500rpm and unstable, engine shut down itself within 5 seconds. When the engine was runing unstable and hesitatly, I tried to push the gas pedal, the RPM won't change, Seems the gas pedal didn't work.
So, I turned the key to off, took out the key, opened the hood for about 30 seconds, then I tried to start the car again. It start normally, everything works well.
It happened severl times, all in hot days. Could you please tell me which parts probably need to be replaced or what can I do?
Thanks.
Sounds like Either the Air Filter is Clogged or dirty, or that your fuel injection system is clogged/malfunctioning.
And according to my taurus service manual, you could have a defective Engine Coolant Temperature sensor.
Fear my airspace
