Old 08-05-2007, 06:43 PM
chris_8222 chris_8222 is offline
Thumbs up Re: need a little help with locating tdc
Originally Posted by jeffcoslacker
No that won't work...the cam and crank go around at different speeds (thus different gear sizes) so you could never guesstimate the degree of the crank to cam correctly and be precise....you'd end up a tooth or to off and it wouldn't run, or run like crap..
Take the other plugs out, it's gotta make it easier. You try bumping the starter and see if the crank will move?
wow i finally got it!!i rotated the cam a little and the crank turned no problem.should be smooth sailing from here i hope.lol.thank you for all your help it was appreciated
Old 08-05-2007, 10:49 PM
Blue Bowtie's Avatar
Registered Offender
I knew you'd get it. Now just go dot-to-dot on the sprockets like the Slacker's graphic, and you'll be all set.
I'm still a little concerned over why it wouldn't turn, wondering if you may have valve train problems. Turn the engine over (with no plugs) very carefully for a few revolutions once it's assembled, just to be sure.
Old 08-06-2007, 11:39 AM
i will try turning it over a few times with no plugs and see what happens and let you know.
Old 08-07-2007, 06:03 PM
wow how silly was i to think everything would go smooth during reassembly. for some reason the pulley will not go on no matter what i try.i lined it up properly but it just wont go.any suggestions??
