Go Back   Automotive Forums Car Chat > Chevrolet > Impala | Impala SS
Old 09-04-2007, 09:39 AM
Lenta Lenta is offline
Re: 2001 LS fuel gauge problem
Originally Posted by Lenta
yes, I did it! Just open the rear seat back< take out the trank carpet and right behind the right side rear seat you will seea small 12 bolt rounded cap. Bolts look very heavy to open or screw out them, but in fact it is easy (!) to screw them out! After that just plug out all connections and pull out the fuel pump. As others say, you don't need to replace all fuel pump, but you can replace only the gauge. I didn't even replace this gauge! I just cleaned it by wipe and other solution (got blacks on eyers cleaning cotton stick!).
Then just putted all back! Didn't spend even a panny except 1 hour to all of this. I sceared in the beginning that i will not be able to do the job, but after 1 hour I was loughfing on myself was dummy before and counldn't start the job! Try, it is easy! First - open the rear seats of you Impala (Pull the back of the seats down). Open the carpet behind them and you will see the srews....Done.
Foggot to tell it is important! Don't smoke siggaretts at this time! Disconnect the battary during the job! Do the job when your gas tank is almost empty! And: go a church or mosque a day before the job. Put there 23 candles: for luck and for sucsess! Step by step remember what you screwed out and in what order in order to screw them in step by step! memorize the position of cup when gonna screw out the cap of fuel pump! Mark them by chouke! or marker! (Make a picture BEFORE the openning the cap to see then positions of all connections, etc! You can also write a letter of trust for your millions $$ for your kids before the job< but I didn't do it since didnn't have the million!
