Old 02-03-2003, 05:57 PM
mellowboy's Avatar
mellowboy mellowboy is offline
Amy dragged me here...
Send a message via Skype™ to mellowboy
Originally posted by crxlvr
ok thats nice for my all motor setup, what octane gas should i run, 91 or 93?
I'd say 93 but i dont think 91 shouldn't do any harm?
Old 02-03-2003, 07:56 PM
BIGDOM BIGDOM is offline
NEW PISTONS
i was thinking about getting new pistons, I have a 90 accord (f22a1), rite now stock compression is 8.8, i found pistons that would bring me up to 9.3,, would this give me a decent power boost? if so how much do you think? and also are there any otha mods necessary for new pistons??????????
Old 02-03-2003, 11:09 PM
mellowboy's Avatar
Re: NEW PISTONS
Are you goin all motor or turbo? IF your goin all motor then go higher compression. LIke 11:5?
Old 02-04-2003, 09:33 AM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
alright sounds good, no more 87 for me.
and for the accord all motor bump your comp ratio way up, turbo or SC it, then drop it low.
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 03-07-2003, 11:16 AM
redmanjd redmanjd is offline
i doesnt hurt your car to run say cam2 because it only has a higher flash point to prevent detonation so i have 10.5:1 cr and i am going to run sunoco94 but fill up at the track with cam2. but i think when you hit 11:1 cr you need atleast 93octane
95 b18b
new crank, eagle rods, je 10.5 : 1 pistons, 8lb flywheel, stage 3 act clutch, billet aluminium and urathane mounts, balanced rotating mass, 14.3 @ 93mph
New additions, teo4h turbo, ssautochrome turbo manifold, custom piping, turboxs bov, dsm 450cc injectors, greddy e-manage fuel controller 13.07 @ 107 untuned
Old 03-07-2003, 12:44 PM
Frostbyte Frostbyte is offline
Send a message via ICQ to Frostbyte
Originally posted by hybridsol
an ex sohc is 9.6:1.....? :huh: 12:1 is up there for a single overhead cam motor.
Actually 12:1 will work fine as a daily driver if you could get the higher octane I would just go with a 11:1 for daily use. I am going to be putting my Single to a 11:1 compression.
1989 s13 Fastback
Tein HE coil-overs
sr20det swapped!
JIC Magic Front and Rear Strut Bars
Slotted and Cross-drilled Rotors
S/S Brake Lines
Pivot Lazy eye controller
Blitz LM Intake
Blitz D1 Spec Turbo Timer
Soon to come:
Sard 550cc Injectors
Blitz Nur Spec Exhaust
Blitz Down pipe
HKS FMIC
http://www.driftmonkey.com (Part Owner)
Old 03-10-2003, 03:46 AM
i agree
95 b18b
Old 03-10-2003, 10:44 AM
seth 90DX/ZC seth 90DX/ZC is offline
Banned
The compression ratio you can run has more to do with the shape of the dome of the piston than the amount of octane. Also a seriouse problem people have with detonation is using stock injectors and thinking shit will be OK, its not. Think about it like this, any FI works by boosting the CR so in order to make up for the vast amount of airflow we use more fuel to get the right air/fuel mix. Now what do you think Hi CR pitons do? They have more surface on the domes which allows more air to be pulled in, but if you dont have the fuel there to feed them what are you doing? Your running realy lean. I would sugest at least a 1/2 inch fuel rail and 270cc injectors for my DOHC ZC 11.16:1 project... Just to give you an idea. Btw Im also going to be using NOS! LOL! Its all in the tuning. Oh Ill be using 110 Oct as well... Since I only drive my car on the weekends its not to expensive, the 110 just doesent detonate like 91. But thats no excuse to use stock injectors.
Old 03-10-2003, 11:51 AM
thats not true compression ratio is the amount you compress the cylinder volume. it has nothing to do with drawing any air into the engine it is compressing the air thats already in their that much more. Why would it suck more air?? the only problem with detonation is the fuels flash point. the fuel is under such high pressure that after it ignite the unburn fuel is re ignited on the up strock by friction caused by the rings and cylinder wall. that is why you need higher octane. because it has a higher flash point. You dont need bigger injector.
95 b18b
Old 03-10-2003, 11:54 AM
also you are right for forced induction because you are making the airflow more dense so more air = more fuel
95 b18b
Old 03-10-2003, 12:09 PM
mellowboy's Avatar
Ditto!
Old 03-10-2003, 12:24 PM
Banned
Der der der... Rookie. Look man, if you want to compress MORE you have to have MORE to compress. Dont tell me I dont know what the fuck I'm talkin about, have you ever built a motor? I didnt think so. I have a turbo engine that uses 28.2:1 CR pistons without the 12-14 Psi Im slaming into it.
Pluss if you have higher CR pistons they have more surface on the face which meens they are asking for more fuel/air because they have more surface they draw more. GO ahead and use your 11 to 1 pistons with stock D series injectors then come talk to me after your engine explodes. I have a D16A6 thats runnin 11.2:1 JE pistons right now.
Old 03-10-2003, 12:45 PM
does nyone agree with him???? what no???? dont get mad at me cause i disagree. if a piston has more surface are you have less volume in your cylinger. higher cr doesnt great a higher vacume. 28:1 that the hell the highest i have ever heard of is 18 on 9 sec dragsters what is special about your car. their is no dought you have a high cr turbo but come on.
95 b18b
Old 03-10-2003, 01:29 PM
Banned
Its a turbo diesel... No sparkies... Actualy you can run a honda engine just like a diesel and use detonation intsaed of spark. You have to do quite a few mods but it has been done before. And no, just because there is more face on the piston does not meen there is less volume in the Cyl. Hasent anyone taken grade school pyshics in here? Explain to me how there is less room with roller wave pistons, and I'll call you an idiot. There is actualy more room and more face on the pistons or that of equal amount as before. Now Im sure there are some REALY shity companies out there (Such as JE, the pistons Im using in my A6) that dont copensate for the volume of the cyl's when they make there pistons. Now what you get then is realy knarley detonation iether way you look at it. Even with less fuel you will still have detonation. It all realy comes down to your knowledge (Or lack there of) and the knowledge of the company you buy your pistons from. Nuff said.
Old 03-10-2003, 03:45 PM
mellowboy's Avatar
Seth are you sayin that u have to get bigger injectors if you're goin high compression? Cause my boy have ctr pistons in his b16 without any upgraded fuel and it runs fine.
