Old 10-31-2002, 08:40 AM
SmoovSol SmoovSol is offline
Send a message via AIM to SmoovSol
might want to check the IACV, if there is a problem with it then its not activating when u turn on ur a/c. The IACV lets u idle a bit higher when u turn it on so ur a/c compressor can suck the amount of air needed from the intake manifold to the compressor. If it fails to do so the compressor will try to still intake the amount of air needed but on idle there isnt any extra air being added so it draws away from ur cars idling air controle. When u do start to drive more air is sucked in so it is supplied with enough air to accomodate both engine and compressor. The IACV is located behind ur intake manifold a little the right, it is bolted onto it and sticks out with a black cylinder on it. Not sure how much it will cost for a new one but that sounds like the problem, the valve trying to open and it might be shorted out thus causing a clicking sound..... there is ur answer... happy posting...
Dont be Afraid Ta Be Different...
Old 11-01-2002, 03:40 AM
Self's Avatar
Self Self is offline
Send a message via AIM to Self
Originally posted by civickiller
you guys all say look at the ac but i say look at a power loss somewhere. the ac draws power fromt eh motor and if the motor, not the ac, is running shitty then when you turn on the ac, it will almost stutter and die. i think the ac is just bringing out the problem. the engine it self is running shitty and whne you turn the ac and it starts to draw power but since the engine is already lacking power it almost dies
i still say injection cleaner and fuel filter, if thats not it then i say vacuum leak. even if the fuel filter is not the problem, since you havent changed in a long time i woudl just get one anyways
I disagree here...I would think it IS the A/C...Mainly because he says he here's a clicking. Everyone is skipping over that detail. I don't know about you guys, but in my car, the A/C makes an audible clicking noise as is starts spinning. If something were wrong with his AC causing it to start and stop spinning continually, it could throw off the revs in some way...I don't really know, just throwing a guess out there...
There's no replacement for displacement...No, not even a turbo.
Old 11-01-2002, 10:05 AM
It couldnt be in your compressor cause if it tried to start and couldnt, your IACV wouldnt open(thus causing a lower rpm cause the a/c is not working properly. So it is ur aicv. If it were in the injector there would be no clicking noises, and turning on the a/c would have nothing to do with a low idle fuel injector problem...
Old 11-01-2002, 06:53 PM
zigen zigen is offline
Send a message via ICQ to zigen Send a message via AIM to zigen
Yeah I defianately will get the fuel filter changed if not a whole tuneup.
Also thanks to everyone who has posted to help me out. Im taking my car into be looked at next week so hopefully they will be at least partially competent. If not I'll just tell them to talk to you guys.
Old 11-06-2002, 01:07 AM
fuel filter and injectors, these are way off. First thing to determine or trouble shoot a problem is determine air, fuel, ignition, pressure... fuel is there only when a/c is turned on has nothing to do with fuel system...
Old 11-15-2002, 03:25 PM
redmanjd redmanjd is offline
check you idle air controll valve. it is designed to boost your idle when the car is under a load such as you a/c
Old 11-22-2002, 12:08 PM
RoBoDEATH RoBoDEATH is offline
Send a message via AIM to RoBoDEATH Send a message via Yahoo to RoBoDEATH
i say tune up, tune up, tune up
even if it doesn't fix the problem it will still help and will avoid future problems, hell right now my car is making metal pinging noises, haha fuck honda
1998 Honda Civic EX--Si Wing--Jackson Racing Supercharger--Enkei RP07 18inch Rims--Yokohama PARADA 215/35ZR/18's--K&N Filter--Hurst ShortShifter--DC Sport Header--Greddy Cat-Back Exhaust--DC Strut Tie Bar--Eibach Springs with Ground Control Coil Overs--Ingalls Rear Camber Kit Arms--Skunk2 Front Camber Kits--Panasonic DF88 CD Player--Two 1Fared Caps--Sony Xplod 800W Amp--SPL Series II 1200W Amp--Solo Baric 15--!!!!!SOLD!!!!!!!
2001 Honda S2000 NFR--HKS Hi-Power Duel Exhaust--NRG Hood Dampers
