Old 10-28-2002, 04:46 AM
civickiller civickiller is offline
Send a message via AIM to civickiller
are the cdn cars different ? i think you need wiring harness unless you you add the 4 wires for the ls. 90-93 integra axles, resistor box, mounts, shift linkage, 90-91 pr4 if obd0 and 92-93 if obd1. the obd0 will bolt to your current harness. thats the major stuff, idk about the little stuff
Old 10-28-2002, 06:02 AM
redmanjd redmanjd is offline
i have put a b18b into my civic dx 90 . i dont get any spark any suggestions i converted my harness to si with the 2 injector wires and 2 sensor wires.
Old 10-28-2002, 12:13 PM
TrailerParkJake TrailerParkJake is offline
Send a message via Yahoo to TrailerParkJake
have you checked all your grounds and made sure they are good?
im not too familiar with the dpfi to mpfi conversion...also did you wire the injector resistor box up as well? any codes?
roberto, you probably want to read up about dpfi ---->mpfi conversions since im pretty sure your car is dpfi and it needs to be mpfi for the b-series motor to work.
When I started reading about the evils of alcohol, I quit reading .
Old 10-28-2002, 01:20 PM
BigBearWest's Avatar
BigBearWest BigBearWest is offline
WWW.CalgarysFinest.COM
Send a message via ICQ to BigBearWest Send a message via AIM to BigBearWest Send a message via MSN to BigBearWest
yah know about the dpfi to mpfi. anything about the interasl? how much boost do u think i can run on internals
My Name is Roberto AKA. Berto
Old 10-28-2002, 02:39 PM
i wouldnt go much past 9 psi on stock internals....just take it to a reputable place to have it tuned real well. My plans include boosting on my b20, what im gonna do is get eagle rods and je pistons...not sure what comp ratio as of yet...probably 9.0:1. Ill worry about resleeving it when i blow something up. What are you gonna use for fuel management?
Old 10-28-2002, 11:18 PM
i'm thinking of going with a stage 2c turbo kit from http://www.revhard.com/turbokits.html
what dou think?
Or should i go with a junkyard turbo?
Old 10-28-2002, 11:36 PM
tbk49's Avatar
tbk49 tbk49 is offline
Send a message via MSN to tbk49
how much $$$$ do you have?? it all depends on how much money you got really
blah
Old 10-28-2002, 11:41 PM
like $4000 i hope
