#16
Re: Security.. Fuel Pump.. Problems!?
The PCM turns on the fuel pump relay.
But first swap relays with another one of same no. There should be several in the relay box. Next find the gray wire or fuel pump prime test wire from relay to fuel pump and jumper it with a 12 volt fused jumper wire. If fuel pump runs and it will start. Your relay is bad or pcm is shutting off relay. If fuel pump will not run with it jumpered the fuel pump or wiring is bad. Let us know how this test goes. MT
#17
After testing the gray wire we found that we had voltage. So we just decided to drop the tank and get a new fuel pump... That fixed it.. All this running around for just that..
My buddy can't believe it was that because it just happened out of no where.. |
#18
What else would you guys suggest to do while the vehicle is still up and half was takin apart.. (Not really) In all seriousness... What else should I change or clean before we finish..
#19
It did pick a strange time to quit.
But they do that sometimes. Always install. New fuel filter. Make sure you use a good quality AC Delco / or Delphi fuel pump module. And make sure the wiring plug to fuel pump is good. Some have a wiring plug change over. And always keep over a 1/4 tank of fuel in the tank. Good Luck
#20
Is there any studies or reports to support the 1/4 tank theory?
"If everyone is thinking alike, then no one is thinking". - Gen. George S. Patton Jr. |
#21
The pump needs fuel in the tank to cool it and lubricate it. Over the last 30 years years I have noticed that. People that keep 1/4 tank or more of fuel in there tank replace a lot less fuel pumps than people that run them empty.
#22
#23
Some Big trucks had them 45 years ago in the tank and the had the same problem. Run the tank empty and they were replacing the fuel pump. I have watched cars and light trucks with them for 30 years. Same problem run the empty and you replace the fuel pump. That is good enough statics for me. But if you want book statics do a google search. MT
#24
#25
Yes dirty filters and even bad wiring and ground to fuel pump..
The wiring is to a fuel pump is not very hevey. Bad wirng can take out a fuel pump to. If you know some people that always run there tank low before putting gas in. Watch and see how many ful pumps they replace compared to people that keep a 1/4 tank or more of fuel in them. MT.
#26
It certainly makes sense to keep the tank 1/4 full if you want to discipline your self to do it. Factor in the wife and kids and it is a new ball game. I have a lot of respect for you and anyone else that has twisted wrenches for that long. I have been doing it for 35+ years myself, but never did it for a living. Thanks MT for all your contributions.
