Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 05-30-2007, 08:39 AM
PeteA216's Avatar
PeteA216 PeteA216 is offline
Send a message via AIM to PeteA216
Re: what does a transmission slip feel like?
pete is almost exactly quoting what i was told by my local trans shop.
Wow, maybe I should get into being a tranny guy!
Old 05-30-2007, 10:34 AM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Uhhh ... I hope you don't live in San Francisco! LOL.
What happens is that over the years, the metal accumulation in the oil will find its way onto the worn clutch discs, which use it in place of the now-useless friction modifiers in the worn oil. New oil washes these deposits away, which results in the death of the transmission as these imbedded metal particles are almost all of what's left of the friction material.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 05-31-2007, 06:40 PM
GreyGoose006 GreyGoose006 is offline
hmmm.
fair enough
i still think that the best thing to do is to change your fluid regularly and not get yourself into these precarious situations
Old 05-31-2007, 10:55 PM
PeteA216's Avatar
Agreed, but for those who have gotten thier cars with high mileage already put onto them, I'd say it's best not to chance it unless absolutely necesary.
Old 06-05-2007, 04:41 PM
mike561 mike561 is offline
since this is a tranny topic, i was backing into a spot and when it was in reverse i put it back into drive to straighten out, and i herd a big "clunk" is that bad? it still shifts and fuctions fine. im going to have the tranny fluid flushed soon, my mechanic says everything else looks good, just that the fluid was a little dirty but not too bad.
2006 Chevy Cobalt LS
Old 06-05-2007, 07:51 PM
silicon212's Avatar
Confoundingly Lucid
That "clunk" is generally the result of worn U-joints, but can also result from wear in the rear axle. U-joints are NOT hard to replace at all, as long as you've got a good hammer (I use a 3-lb cross-pien) and two sockets - one that fits within the cap and one that fits over the cap - so you can drive the old one out. They're also pretty cheap (under $10).
Old 06-05-2007, 09:27 PM
PeteA216's Avatar
My Caprice does the same thing, as does my pickup. The caprice has done it since I've owned it and the truck has done it since it was brand new. I don't know about the Caprice, but I know the truck has play in the differential gears because you can move the driveshaft back and fourth by hand a little without moving the wheels.
Old 06-05-2007, 09:50 PM
k so it doesnt sound too major then
Old 06-06-2007, 09:40 AM
Scrapper Scrapper is offline
AF Premium User
your fywheel could be loose also if it's not the u/joint's or even torkconverter and check the pinion bearing....good luck..
Old 06-06-2007, 10:26 AM
silicon212's Avatar
Confoundingly Lucid
It won't be the flywheel (actually a flex plate on these engines) or the torque converter if it does it on a shift from reverse to drive and vice versa.
