| Latest | 0 Rplys |
| Exterior and Wheels This is the place for all exterior wheel modifcations. |
Show Printable Version | Email this Page |
#16 | |
Re: 18" rims fitting on '99 eclipse
They should be fine unless they're like 18x10's or something. I'd get that "popping noise" fixed first though.
#17 | ||
#18 | |
![]() Join Date: Apr 2007
The tires on the rims are 225-40 on 18s. Rim measure 8" across width ways and they only make popping noises when the car is getting lower back to the ground.
'99 Eclipse ( 10 year anniversary edition) ( non-turbo) And a toyota 4runner truck in progess. |
#19 | |
225's will be fine. Regardless of the popping noise coming from the rims or not, a popping noise in the suspension is not a good thing and it's something I would get checked out ASAP.
#20 | |
![]() Join Date: Nov 2005
Hmm..rotating mass. As long as the weight is matched by performance to us the rim then it shouldn't be an issue, if the rotating mass is greater by weight than the 'stock' set up , it can have a huge impact on 'performance' such as 0-60's , brake wear and tear , bearings , etc.
I think anything over a 16 is too much for such a puny vehicle which is why I am sticking with those as the 16's I have are obviously bigger than the stock 14's but they weigh in at 9 lbs less each with tire. ![]() But for show and what not 18's are ok I suppose. That rim looks heavy as a mudda fugga though.
2004 Mazda 6i 1997 Tahoe |
#21 | |
Tons of people have 17s, 18s, 19s, and I've even seen 20s in a few cases. I know I'll be putting some 19s on the Talon when it's finished, but they're pretty light and they look badass. As long as you get a camber kit, you shouldn't have any excessive wear on the bearings.
#22 | |
Hey Blck99GST... i notice it says no cat under things dine to your car...i'm new at this if you hadn't noticed but did you take it out?
#23 | |
Correct...there is a lack of a catalytic converter under his car.
#24 | |
What does that do? My car smell sometimes and someone said that it was that. what do you think it smells like rotten eggs.
#25 | |
Dave is THAT guy
Rotten egg smell is usually the heater core from what I've heard.
2013 Chevy Sonic 1LZ Daily Driver, 1.4L Turbo, 6spd 75 Monte Carlo SBC 400 6.6L, Aluminum heads, Hurricane Intake... 12 Chevy Sonic 1LZ 1.8L - Traded 01 Pontiac Grand Am SE - RIP 95 Eagle Talon ESi-T 5spd - RIP 88 Oldsmobile Cutlass Ciera- RIP |
#26 | |
ok thanks
#27 | |||
![]() Join Date: Jan 2005
'92 3000gt SL Zoom Stage 1 Clutch Quote:
#28 | |
Hey l_eclipse_l i tried to send you an e-mail but don't know if it worked i was going to ask you if you ever tried 18" rims on your car? Cause we have basically the same car...kinda, you've probably done more to it but i hope to.
#29 | |||
#30 | |
Oh ok thanks. How long have you had your car?
