Old 08-17-2007, 03:51 PM
Hugemoth Hugemoth is offline
Re: '93 Metro Broken Door Handle Lever
My handle cracked today in about the same place. Thought about just swapping out the broken piece from the passenger side but didn't feel like taking both doors apart. Instead I melted the plastic back together with a soldering iron then reinforced it with .032" stainless steel safety wire. The way I used the safety wire was to heat the wire and push it through the plastic, basically sewing it together with a couple loops of wire twisted at the ends. I think it will be sturdier than stock.
Q
Old 08-19-2007, 12:53 PM
RossT RossT is offline
Mine broke today too. Junk yard is closed so I super glued it and then used epoxy puddy. I tested it and it's really strong. Next time I am at the yard I will get another one,but for now mine is doing fine with the epoxy.
Old 08-19-2007, 03:57 PM
DOCTORBILL's Avatar
DOCTORBILL DOCTORBILL is offline
Geo Metro Lover
REMEMBER ! - you can use either side door handle to fix any door handle!
Geo door handles (the part you pull on) are symmetrical. Take the handle out of
the assembly and you will see that that this is true.
Either side can be used to fix either side. The designer was intelligent - only need
a hot metal mold for one handle - use it for both sides!
So all those passenger door handle left at the junk yard because someone's
driver's side broke are yours for the picking!
DoctorBill
Old 08-19-2007, 04:11 PM
Not only that, but you can simply swap the part of the handle that breaks from one side of your own car to the other and avoid a trip to the wrecking yard.
Q
DoctorBill
Old 08-19-2007, 10:49 PM
Very good point. I saw the hole on the other side, but didn't think to switch it to the useable side. Thanks for the heads up.
Old 10-22-2007, 05:32 AM
Woodie83's Avatar
Woodie83 Woodie83 is offline
Bump. This is too valuable to be this far down the page.
Woodie
98 Metro and 06 Aerio SX
Don't waste your vote on one or the other of the Republicrats, vote for Gary Johnson and really do something for a change
http://www.garyjohnson2012.com
