Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 03-19-2007, 10:42 PM
rdiggidy rdiggidy is offline
Re: Dead battery, then dead car??
Originally Posted by DFBonnett
OP,
I looked at the same manual. Doesn't seem like an IAC is being used now.
You might try cleaning the throttle bore and plate with carb cleaner and a toothbrush then disconnecting the battery for a few minutes to allow the comp to reset to default then try again. I had the same problem on my Crapillac and that was the cure.
FWIW
YMMV
I feel a little better knowing that it appears not to have one...I was getting very frustrated trying to figure out where it could possibly be.
The throttle body has a thin film of "grease" on the inside (bore and engine side of plate), but doesn't have what I'm use to seeing as a grainy build up. Overall it seems pretty clean, but I'll give cleaning and a comp reset a try.
Thanks for all the help, I've been feeling like this--->
