Old 04-04-2007, 01:16 AM
goldz28's Avatar
goldz28 goldz28 is offline
Re: Son looking for a 3rd gen
Sweat deal man, Post up some pics when you have time.
2008 G8 GT ~ 2004 Silverado LT ~ 1998 z-28
Tuned By TJ Wong - Wong's Performance Engineering
Old 04-04-2007, 12:07 PM
rob67gmc's Avatar
rob67gmc rob67gmc is offline
Took a few pics today but not sure how to post them on this forum. It's a little different from my gun/hunting forums.
First problem I need help with is the throttle is sticking when I try to ease on the gas. It only does this when the car is running, doesn't stick at all when it's off. Any ideas?
Rob
Old 04-04-2007, 03:33 PM
Morley Morley is offline
Throttle "sticking" only when the engine is running tells me that someone did a "rebuild" if the throttlebody (put bearings in on the shaft for the dreaded loose throttle shaft) and didn't wind the return spring back on it properly OR the throttle shaft is very loose in the bore and the vacuum of the engine running is cocking the throttle blades in their bores.
For the first possibility you'd need to remove the arm from the shaft and get the spring positioned properly.
For the second you'd need a "rebuild" of the throttlebody which involves a bit of machine work to get it apart, opening the shaft bores for the needle bearings to be installed, then a little more drilling and tapping to put it all back together.
I've done a few of the "rebuilds" myself. If you need further advice/info on the process, etc. just PM me.
Old 04-04-2007, 03:50 PM
ZL1power69's Avatar
ZL1power69 ZL1power69 is offline
GM S-Series Mod
Congrats, sounds like a sweet ride. use a hosting website like imageshack to host the images. you have to do them one at a time. then when you post a reply, use the image icon and paste the link for the image.
2000 Chevy Blazer ZR2
Performance Mods: Numerous
Suspension Mods: Some, but not enough
Exterior Mods: Just Right
1987 Buick Turbo T Dark Red
Low 11 sec sleeper
.030 4.1 block, PT6262E, & other odds and ends....
My Cardomain
Old 04-05-2007, 01:37 PM
rob67gmc's Avatar
Morley,
The BBK 58mm throttle body was purchased from Summit in Feb. 2006 so nut sure if it has been rebuilt only being one year old. My thought were engine vacuum hold the blades closed. The throttle shaft seems tight to me. I'll check the spring position and go from there.
ZL1,
I've used Photobucket before so I'll give that a try.
Thanks for the help,
Rob
Old 04-06-2007, 09:53 AM
rob67gmc's Avatar
new pics posted in Members Rides Showcase
1989 Camaro RS convertible
Engine & trans has been changed to 350 TPI w/ 6-speed manual
K&N filter
BBK 58mm Throttle Body
Richmond 3.73 gears
Spohn full length adj. torque arm
Spohn lower control arms w/ poly bushings
Spohn Adj. panhard bar w/ poly bushings
Spohn front & rear sway bars
Spohn weld-in subframe connectors
PST complete front end rebuild kit
KYB struts & shocks
Old 04-06-2007, 11:03 AM
Morley,
BBK's are known for sticking. If the spring is on wrong, engine vacuum will open the blades.
Old 04-07-2007, 09:14 PM
rob67gmc's Avatar
Since my son and I are no longer looking for a 3rd gen, I'm going to quit using this thread and start a new thread in the "Problem Daignosis" section about the sticking throttle cable.
Thanks for all the help so far!!!!!!
Rob
K&N filter
Richmond 3.73 gears
KYB struts & shocks
Old 04-14-2007, 04:15 PM
89Firebird2.8's Avatar
89Firebird2.8 89Firebird2.8 is offline
I like all the f-bodies except for the early 2nd gens. I drove my buddy's 79 Z28 with the 350 and it was the shite. Those dual exhaust w/cherrybombs sounded nice. I also like the 77 T/A used in Smokey and the Bandit. I'm hoping to upgrade from my 89 2.8 to my dad's 67 400 in the future.
2012 Ford Fusion SE 3.0 V6
-SOLD- 1992 Lexus LS400 4.0L V8
-SOLD-1989 Firebird 2.8l V6 Red and White w/flames. Stock. Daily Driver.
