| Latest | 0 Rplys |
Show Printable Version | Email this Page |
#16 | ||
Re: 95 lumina overheating problem
#17 | ||
i must have messed up when i put it together.iwas hoping it may be something simple but what can you do i guess ill take it apart again and see what is going on.thank you very much for all of your suggestions and ill let you know how i make out. |
#18 | ||
#19 | ||
#20 | ||
#21 | |
yes i checked the oil and it looks fine and is at the same level as when i filled it.no silicone on the gaskets?the manual says to use a thin bead on the intake gaskets.why should i not use any?
#22 | ||
#23 | |
I have the same identical problem. I haven't replaced the head gaskets though. But I have replaced the thermostat and sensor. What is really weird is when I first fixed it it ran fine for a day or so and now if I drive around the block it overheads again just like yours. I am lost as well, bled system etc. And sense you already replaced the water pump and have the same problem I can't see doing that.
If you solved your problem I would be grateful for a reply. If I solve it I will get back to forum. If anyone else has any ideas I would be grateful as well. I can also be emailed directly at [email protected] |
#24 | ||
#25 | |
well i took the whole engine apart again and didnt find any cause for the overheating problem.i replaced all the gaskets with new ones not taking any chances.put the engine back together again and it ran fine...for about three or four hours and then started overheating again.i had a mechanic help me put it all back together to make sure i was doing it properly and as far as he could tell everything went well.he lives a long way from me so he was not here when i started the car.i bled the system until absolutly no air came out of either bleeder screw.im at my wits end
could this be some sort of sensor?if anyone has any ideas please let me know. |
#26 | ||
#27 | ||
#28 | ||
#29 | ||
#30 | ||
