| Engineering/ Technical Ask technical questions about cars. Do you know how a car engine works? |
#16
Re: Theory: Using brakes to assist traction with an open differential
Hey...
For the rest of the part, lets say that the torque does get divided equally between the two wheels. So, in this situation, the torque provided to the differential is 2Xr, and the torque provided to each wheel is Xr, ‘irrespective’ of the traction available at each wheel. So if Xr torque is provided to the right wheel(which is the one on tarmac), it should be able to move the car ahead, because the same traction is still available, and hence it should offer the same resistance to turn, irrespective of what the other wheel is on, tarmac or slush. This means that the car should move ahead. But that does not happen in an open diff. So then, the way I see it, there seems something not right. If the above were true, then we would not require limited slip diffs. So I think the torque will not be split equally. Thanks for bringing it up, food for thought. Cheers
http://theblogonwheels.blogspot.com |
#18
wait.
the ammount of torque is dependant on the ammount of braking force too if you just tap the brakes, the brakes will not put enough torque on the spinning wheel to overcome the traction of the gripping wheel and move the vehicle foreward. however, with an engine that is capable of putting out enough power, and the brakes applied adequately, the rear wheels will act as if they are locked together. i guess its all a moot point though because limited slip diffs and 4wd (or even 2wd and decent tires) can get you thru just about any scenario that you are likely to find in normal everyday driving. |
#19
While it doesn't take much to move a car on a flat and smooth surface, if you've got a wheel slipping then you're probably not on a flat and smooth surface. Front wheels sinking into snow or mud can take a lot of force to dislodge. |
#20
The Australian Ford Territory and GM-Holden use a AWD system with open differentials and use the disc brakes to control traction (controlled by a Bosch 5 traction and dynamic stability control system). Differences in individual wheel rotation rates trigger intermittent braking intervention to control traction... both systems also have optional driver selectable hill descent control...
A wheel slipping will have a rotation speed significantly greater than the other wheels so once braking occurs on that wheel, torque is redirected to the other wheels. Mechanical LSD operate locking mechanisms that fix the rotation speed of the two output shafts so that wheels on the same axle rotate at the same speed and receive similar levels of torque....
I resent being called a misogynist and a psychopath... Contrary to popular belief I don't hate women I hate mankind in general and that makes me a misanthrope - Psychopaths engage in antisocial behaviour unknowingly - I have empathy and moral responsibility I just value my own personal needs more... that makes me a sociopath. |
#21
2007 Certified DaimlerChrysler Service Technician... True blue GM at heart. |
#22
That small difference is traction control applies brakes to individual wheels as needed, not to all four (brake pedal) or one pair (handbrake). Making it a completely different situation. |
