#16
![]() ![]() ![]() ![]() You could be the lead actor!![]() Quote:
I will try to address your initial problem when I get through laughing at all your post! ![]() ![]()
Knowledge can be communicated, but not wisdom! ![]() ![]() |
#17
Re: Code 14 (Kiss of Death?)
See, I'm glad I asked....I've never heard about how to purge air from the system, and with a 16 year old car that I cherish (and am not ready to relinquish) it's a good thing that I asked before I did something retarded.
**something ELSE retarded, as I have been driving my car in this un-burped condition ![]() If you want something to laugh at, the ghetto fix for my airbox is just a k&n clone cone filter strapped directly to the throttle body. When NO ONE stocks parts, what more can I do to make my car drivable? (and it looks cool IMO, though putting your air intake right above the exhaust pipe isn't the *best* way to get cold air) |
#18
What more can you tell me on playing with the thermostat? I'd rather do it right this time, the first time.
#19
Alright, I have another progress update here.
I ran the engine for a while with the radiator cap off, but the coolant level didn't change....still high tide in the radiator. So I, after looking through my massively mislabelled Chilton manual found the valve on my thermostat (lol--the only one that was designed to be unscrewed) and gave it 3 turns. For that effort I was rewarded with a tiny trickle of green coolant. I ran the engine like this (both valve and cap open) for a minute or so, then shut down the car, replaced the cap to the radiator, and started the car back up. (with the thermostat open) After seeing nothing but an even Smaller trickle of green liquid, I decided I'd shut the valve on the thermostat for a while. So, as I let my car idle, I re-tightened the clamps on my ghetto fix air filter, and found that I'm sucking in some beastly hot air with this method ![]() After letting my car run enough to reach 'operating temperature' (and the America song from the team america movie soundtrack just ended) I decided to open the thermostat valve again, just to see what would happen. Well, all I can say here is that I think my thermostat works, because at the higher engine temp the thermostat apparently opened to allow coolant circulation, because the pressure was increased enough to cause a 4 inch green stream of coolant to blast out of the valve, and land directly on the exhaust. As AF mentioned, coolant on the exhaust does in fact produce white smoke, and needless to say my little plume of white, noxious 'holy' smoke was pretty cool. So in the end, it looks like the current IS circulating, though I don't believe I put in as much as I got out...during experimentation the coolant level dropped in the radiator, but I think that was just from what came out the bleed off valve on the thermostat. So I haven't solved my coolant amount problem, and I STILL have no answer to the Code 14 error ![]() Once my car cools back down I'm going to check the coolant level, and stick a voltmeter into the plug for the coolant sensor and see if 5V is really going to it.... |
#20
After reading this thread again and regaining my composure,
![]() I have some additional thoughts. I noticed that your focus seemed to be on a possible sensor malfunction, rather than trying to determine if the engine was actually running hot. Have you checked the thermostat to see if it is opening all the way? (You can remove the thermostat, place it in a pan of water on a stove, and bring the water up to 195 deg and it should be fully open). Do the fans ever come on? Do you ever here any gurgling noise coming from the radiator overflow or reservoir? Is your upper radiator hose hot to the touch?
#21
The upper radiator hose (the one that hooks to the thermostat) gets hot, yes.
I focused on a sensor malfunction because that's what I heard Code 14 meant--coolant temperature sensor bad. I saw an explanation that said that when error 14 was thrown it meant that there was a resistance of 'infinite' ohms across the sensor, meaning it was D-E-D. I don't know how correct that is, but it would make sense. BTW, I don't know if this is related, but there seems to be more power under the pedal in my car after trying to bleed the cowardly nemisis of air out of the coolant system. |
#22
Try this; Remove the radiator cap and start the engine and let it idle until warm or until you see some circulation through the system. (Feel for hot top hose) Bring the engine RPM up to approximately 1500 and fill the radiator slowly with coolant. Fill to the top of the fill neck and install the cap with engine still running @ 1500. Let the engine come back down to idle, then open/close, the bleed screw several times to release air. (Wait 1-minute between burps) Only coolant flow from the bleeder valve is an indication that the air has been expelled. Shut the engine off. Fill the overflow tank two or three inches above the "full hot" mark. If the cooling system does not have leaks, the level of coolant in the recovery tank will drop as the system cools down and it will pull coolant in to make up for displaced air and thermal contraction. Bring the level in the recovery tank back up to "full cold" if need be, and maintain the level daily until it stabilizes. You can repeat the fill/burp procedure, for several days to help stabilize the system if you like. ![]()
#23
I would take the car out for a drive.. If you havent already. 5 miles or so should do it. Most air traps in the upper parts. (duh.. that was silly). If you squish the upper radiator big hose you may see the overflow side bobble and fill jiggles a bit. I see no harm if your fluid is passing out to the radiator do drive a while.
Perhaps its time to address the coolant sensor lines back to the computer. Oh,, and after you finally hooked it up did you disconnect the battery 10 seconds and reset the codes and see if it comes back? I show the circuit returning to: BLUE connector PCM pin 9.. if I read it right.. its just the sense return.. Its yellow (that dont look good) a YELLOW.. wire shown from the sensor and into the PCM.. It is numbered 410 at the PCM for some reason on my schematic. THe Black comes back through a connector labeled B/H, possibly referecing the firewall BULK HEAD connector and shows to Join/split/share the same line from the throttle position sensor black.. In other words you can check for continuity from the black TPS sensor and the Coolant sensor black.. That way you know it makes it back to the Computer and dont have to worry about it since your TPS is ok. Basically its the low side of both sensors. I'm making an assumption here but perhaps the black provides a something like the 5v and the yellow returns the difference.. not sure whether it will go up or down on the voltage but it should change with temp change. Hope that helps.
Bass 00' Park Ultra ![]() 94' Park Ultra 94' LeSabre 96' LeSabre
#24
I had the battery disconnected for hours while I installed the new sensor, and when I hooked it back up, I still had the error 14 logged.
Is there another step to resetting error codes, other than power deprivation? For the advice about running the car up to see coolant flow, I'd love to take the LeSabre-orean up to 1500 rpms and go back in time to when I didn't have a check engine code, but GM didn't see fit to outfit my ride with a tachometer ![]() I'll follow you're advice about coolant flow testing, and I'm hoping that some wire didn't get severed.....because that would be bad, to say the least. I'm hoping that I just missed some step in clearing error codes--hoping being the key word. |
#25
There is another way to clear codes but it's just as efficient...
Many code readers have a function choice to clear codes. I haven't heard of just one sensor line going bad inside a PCM but it isn't beyond possibilities. It would be more reasonable that more has gone wrong inside than just that code's input line and not having symptoms encourages that presumption. Wires aren't too bad to replace. Their routing and protection is perhaps more difficult. On that thought a test line could be spliced in running from the sensor to the PCM, just to see if the code clears. Still on that subject with the battery disconnected and the wires off the sensor an ohm meter check to ground would show the continuity to something or nothing. Nothing, max resistance, would more likely be a bad or broken wire and an almost perfect short to ground would be suspect if there was found no open line.
#26
I don't have a code reader (100 bucks I'd rather keep in my pocket)....OBDI was the way--a free paper clip can tell you what a 100 to 200 dollar device does
![]() Of course, for our 1996+ bretheren autozone exists to offer free scans to beat down the man, but still..... So it looks like it's time to get down and dirty with my tinkertoy voltmeter.....I'll let ya'll know what I find....I don't know if I want the 5V across or not....either one sounds annoying to fix. Is it so bad to want to wire a switch into the SES light circuit?? Check Engine Light..... _NO_ check engine light...
#27
Click Here for OBD I code list and instructions on how to retrive codes.
#28
Alright, another update from the garage:
I decided to test the wiring to the coolant sensor, so I liberated the plug from the sensor, fired up the vintage engine, and watched what happened. The coolant fans kicked in, and suddenly it was like I stuck my hand in a jet engine. The coolant fans work, that's a fact, cause I went from 40 degree weather to feeling frostbitten. With a little luck (stupid short cables!) and some fancy fingerwork, I managed to slap those probes into the plug. Suddenly, with the completed circuit, the fans dropped out, and I read a little less than 6 volts. That action makes sense, as the voltmeter has a large resistance value, and a large resistance from the coolant sensor (100kOhms) at it's coldest assumed possible measurement. I'm supposed to be seeing 5V across the plug, but those volts were ranking in just short of 6...even my $10 walmart wonder multimeter shouldn't be off by almost a whole volt on a 10V scale......it was clearly past the 5.5V mark. Is this fluxuation normal? Could the increased voltage be the cause of my problem? I'm not a fan of that theory, but I can't rule it out just yet. I'll see about getting my partner in crime to use his DMM to get a reading....though I still am certain that it won't be 5V exactly. Oh, and if it helps us solve the mystery, here's how the little yellow dashboard friend came to be: I was cruising along the local state highway, and my ride seemed sluggish and lagging, like driving the chevy cavilier of yore....so I was looking for an excuse to break my ride out of the slump.....needless to say an excuse appeared, so I let up and hammered down on the go pedal, and there was a sudden lapse in acceleration, a "cough" I guess you could call it, a sputter, and then a loud sound as my ride suddenly sprang to life and starting smoking asphalt. As I let up on the accelerator, I noticed that the little yellow light that I'd never noticed before was on. And so the tale of the wonky Code 14 began ![]() Hopefully you guys have some ideas, cause I'm out. |
#29
I took the sensor out of the circuit to measure the voltage.
