Old 01-18-2007, 08:23 PM
beef_bourito's Avatar
beef_bourito beef_bourito is offline
Re: dumb question but need help
Originally Posted by GreyGoose006
right but seeing as how they are so different, it is sort of agreed that wrench torque is meausred with different units than car torque.
at least thats how it is here in the US
i agree with 2.2, they're the exact same thing, same units, same concept, that's how it's measured in canada, the us, and the UK. the units for torque differ in the SI (system international) system, the EE (english engineering), and US systems. in the SI system (what most of the world uses) it's Nm (newton meters), in the EE (aka the english gravitational) system it's in lbf-ft (pounds-force foot), and in the US system it's lb-ft (pounds feet).
Mr. T doesn't pity anyone who likes the Black Eyed Peas. He just kills them.
Mr. T speaks only when necessary. His main form of communication is folding his arms and slowly shaking his head. And regardless of the situation, he is always understood.
On the A-team, Face , Haniabal, and Murdoch were all masters of disguise. Mr T didn't have to wear a disguise. The bad guys didn't recognize him out of fear.
Old 01-18-2007, 09:34 PM
UncleBob UncleBob is offline
AF -Advisor
the difference, to reiterate, is torque wrenches quite often involve no "work" (ie motion/movement/time), where as engines always involve "work"....since they have to be rotating to run.
If we were discussing electric motors, for example, they can produce a lot of toque with no motion
life begins at 10psi of boost
Three turbo'd motorcycles and counting.
Old 01-18-2007, 09:57 PM
2.2 Straight six's Avatar
2.2 Straight six 2.2 Straight six is offline
That thing got a Hemi?
Send a message via AIM to 2.2 Straight six Send a message via MSN to 2.2 Straight six
max torque @0rpm.
Seatbelts Saved My Life
Old 01-18-2007, 10:25 PM
KiwiBacon KiwiBacon is offline
Originally Posted by beef_bourito
if this was right it would mean that work is measured in N * m * radians. it's just newton meters, which are equivalent to joules. as well, power is work/time and work is measured in newton meters, time in seconds, this would mean power = Nm/s, not Nm*radians/s.
Back to school for you.
Dot product vs Cross Product.
Nm are the units of torque (cross product)
Nm are also the units of work (dot product)
Converting work to power is as simple as dividing by time.
Radians are a dimensionless unit.
Old 01-18-2007, 10:29 PM
GreyGoose006 GreyGoose006 is offline
thats it...
i was in math class today and was trying to remember what the unitless unit was.
radians of course.
Old 01-18-2007, 10:36 PM
kk i wasn't sure what you meant by radians, i though you were refering to an angle. and yeah, i knew about the cross product being torque (also known as a moment about a point, line or axis) and the dot product being work, it was just the radians that messed me up.
Old 01-19-2007, 02:44 AM
Radians are an angle.
2pi radians in a complete revolution. One radian is approximately 173 degrees.
Old 01-19-2007, 03:35 PM
i thought it was more like 57.
360* / 2(pi) = 57.29
Old 01-19-2007, 03:44 PM
yeah, but when you're finding work and torque you don't multiply the two together then multiply by the angle, you multiply by either the cosine of the angle or the sine of the angle. radians do have units, the sine, cosine, tangent, etc, of them don't.
Old 01-19-2007, 04:06 PM
Right you are, not sure where I got 173 deg from.
Old 01-19-2007, 04:11 PM
Torque is already resolved into tangential forces acting at 90 deg. Hence sine and cosine of the angle aren't needed (sine 90 = 1, cosine 90 = 0).
A radian is a length ratio, (arc length/radius). For a circle measured in metres the units are (metres/metres), which cancel each other out to become a true dimensionless factor.
Work = torque(Nm)*angle(radians).
Power = work/time
= torque(Nm)*angular velocity(radians per second).
Old 01-19-2007, 10:56 PM
why use radians any way?
they have such limited use, and degrees are so much easier to explain (and understand)
Old 01-19-2007, 11:12 PM
To use degrees requires a more complicated formula.
Revolutions is the easiest to explain but radians makes more mathematical sense.
