Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 05-15-2007, 07:00 PM
fanworks fanworks is offline
Re: Miles to the Gallon on a Dodge Ram
I'm justing waiting for the old 360 to give up the ghost, then its off to find a donor truck to pull a nice 12 valve cummins and tranny out of to swap into the 4x4.
CB Channel 17
Space Ghost
'1992 Dodge W-250 Club Cab Long Bed V8 5.9l 4spd H.D Auto 4x4 4.10 Gears
'1974 KIT 11' Kamper
'1987 Custom Built Pullman Mini Camper (The Pullman Mini Camper Project)
'2004 Bi-Mart 1000lbs Cargo Trailer (Chuck wagon)
Old 05-17-2007, 09:42 AM
Chris Stewart's Avatar
Chris Stewart Chris Stewart is offline
AF - Advisor
Thumbs up Re: Miles to the Gallon on a Dodge Ram
Originally Posted by xfeejayx
I want to know! I'm looking to get a cummins, but MPG difference between the hemi and the cummins plays a large role in which one I get.
With the stock injector nozzles I got 18 to 19mpg and now with the #3 Jammer nozzles I got 21.1mpg and lots more power but alot more exhaust heat too if I "stay" in it
1992 Bravada, 201K, stock
1997 Bravada, 101K, stock...was "called away"
"Cornbread Red", 2001 Dodge 2500,4X4,HO Cummins Diesel,QC,SWB,6spd.,Banks boost&pyro,US Gage fuel press.,Edge Drag Comp,4"exh.,cowl hood, bhaf, black Holley pump, 140gph...13psi WOT, Vulcan Big Line, kevlar/ceramic single disc clutch, cheapo fuel cooler, 8x.010" vco injector nozzles, Cat turbo 62-65-.70A/R, 497hp 1089 tq 8/25/14
Time to turn so's you don't burn.
Old 05-18-2007, 06:08 AM
docscomputers docscomputers is offline
1998 Ram 1500 4x4 gets 13-14mpg w/360 Mag, I have a friend that removed his front shaft and claims to get 19-20mpg same truck.
Docs
Old 05-20-2007, 01:44 AM
scavengerspc scavengerspc is offline
Usually around 17.5mpg highway.
2006 Ram 1500 Quad Cab 4.7.
Dave
Old 05-20-2007, 01:52 PM
funcruise funcruise is offline
et.
With my 94 two wheel drive Cummins engine with auto trans I can get 25mpg empty in the summer and goes down to 19 or 20 in winter. Thats an imperial gallon though which is a bit bigger than an American gallon. Also thats driving 60 mph. When I pull the horse trailer it drops to around 17 to 18 mpg. hand calculated from fill up to fill up....Truck and loaded trl. is 14k lbs.....The hemi wont come close to that im sure..
94 ctd 2500, bhaf,4in exhaust, kat missing, 2wd, #10 plate with boost elbow, egt,boost and tranny temp gauges by Hewitt on pillar, gn hitch, and a few more things..
Old 05-24-2007, 07:06 PM
Dyno247365's Avatar
Dyno247365 Dyno247365 is offline
What are all the things I can do to get better mileage from my 5.2 stick? I heard Lucas fuel injector cleaner, ...taking off the front shaft??? and being a manual should help, I should keep it in top gear and stay around what mph/rpm on long highways?
Would a cold air intake help?
1996 Dodge Ram 1500 5.2L 5spd!!!
1987 Chevy Iroc-Z- -Needs a new cat
1992 Nissan 240sx 5spd- SOLD
Old 05-24-2007, 07:30 PM
crazys182003's Avatar
crazys182003 crazys182003 is offline
If you get a cold air you also need to get an exhaust. More air in needs a way out as well. I got a stick as well and get lately 12-14 city and 17 highway. The typical rpm range is 1500-2000 for best gas mileage.
Old 06-10-2007, 12:00 PM
bratt bratt is offline
all I know is these dodge rams are GAS Guzzlers. The fuel MPG seems to vary all the time depending on the way you drive? the best MPG I get is driving from california to utah on flat highway in cruise control. BUT when we drive it hard and drive it up hills. IT eats everything up fast.
Right now gas is about $3.75 a gallon. We fill up at COSTCO because its $.20 cheaper. It cost about $81 to fill the entire tank up. The tank last about 2 to 3 days because we use it every single day. We have 270,000 miles on a gas motor with its 2nd tranny on it. This is the 360 5.9L v8
Old 06-15-2007, 04:11 PM
society909 society909 is offline
My 2001 3500 Quad cab with a cummings turbo diesel gets over 18 mpg. around town and well over 20 on the highway.
Old 06-16-2007, 12:22 AM
Cummins not cummings
Old 06-22-2007, 10:06 PM
flabigboy flabigboy is offline
I just bought a 2005 1500 ram with the hemi. Does a k&N cold air filter give you better gas milage or just better performance. I have friends with ford 250's who have changed chips it doesn't void the warranty and gives you better milage. Anybody know anything about that for a dodge.
