Old 01-08-2007, 06:24 AM
03cavPA's Avatar
03cavPA 03cavPA is offline
Re: Computer runs like a snail
I agree w/ Oz. A clean reinstall works wonders for all the remnants of programs hanging around on your system.
“The ultimate result of shielding men from the effects of folly is to fill the world with fools.”
Herbert Spencer , English Philosopher (1820-1903)
08 HHR
95 JEEP CHEROKEE SPORT
Old 01-10-2007, 01:29 AM
eversio11's Avatar
eversio11 eversio11 is offline
Send a message via AIM to eversio11
Oz - Sorry for the late reply, but I'd be very interested in learning about these programs that make backup/reinstall easier.
"The greatest Americans have not been born yet,
they are waiting
patiently
for the past to die"
Old 01-10-2007, 09:45 AM
'97ventureowner's Avatar
'97ventureowner '97ventureowner is offline
Originally Posted by l_eclipse_l
CCleaner also lets you delete startup programs, which I found useful. Just don't delete stuff that you have no idea what it is.
I run CCleaner on my computer and do a backup as recommended. After I scan for issues, and before I attempt to fix those issues, a box comes up and asks me if I want to do a backup, which I always do.If you do that, can't you go back through that backup you did and "undo" those changes you made if you should change or delete something you shouldn't have?
Thought for the Day… Alcohol does not make you fat - It makes you lean... against tables, chairs, floors, walls and ugly people.
If a prostitute here in America loses her job to a prostitute in India , is that considered "outwhoring"??-Jay Leno
" A Good Thing To Know"
Old 01-10-2007, 10:03 AM
YogsVR4's Avatar
YogsVR4 YogsVR4 is offline
Funding the welfare state
Send a message via AIM to YogsVR4
Another thing to do is clean up is your profile. Anything thats part of your profile (documents and settings\<login name>\...) takes up resources. As an example, iTunes defaults to a subdirectory in there. Now XP has to dedicate resources to them. Get large files off your desktop. Move your music and pictures to an alternate location.
Do those few things and you'll have a nice bump in performance.
Resistance Is Futile (If < 1ohm)
Old 01-10-2007, 10:07 AM
Oz's Avatar
Oz Oz is offline
Aussie Mod
Send a message via AIM to Oz
BACKUP YOUR DATA:
http://fabs.dyndns.org/autobackup/au...up.php?lang=en
Create a new folder called Backup, and use the above software to auto-backup most things on your hard drive.
It doesn't do Custom Office Templates or Email Signatures, you'll need to do them manually.
Likewise, it won't backup any custom folders you have data in on your hard drive, copy them into backup manually as well.
Create a folder called Drivers inside the backup folder, and then sub-folders inside that called "fast" and "full".
Use this software called WinDriver GHOST to backup all your drivers.
http://www.majorgeeks.com/WinDriver_Ghost_d1744.html
Do a fast backup first, then do a ful backup just in case.
Now make a list of all installed software on your PC in a file called Programs.txt in the Backup directory.
Copy the backup directory elsewhere - a network share or external drive. Run a antivirus and anti spyware checks over it.
Reinstall Windows, use Fab's to restore all the stuff it autobacked up, reinstall the drivers manually, copy other folders back manually.
I think that covers most of it, hope this helps.
Originally Posted by RaeRae1
Blessed are the cracked ones for they are the ones that let in the light.
Old 01-10-2007, 10:28 AM
eversio11's Avatar
Thanks mate, I'll give it a shot when I have some time
they are waiting
patiently
Old 01-10-2007, 01:39 PM
Oz's Avatar
Oz Oz is offline
Aussie Mod
Improve your system design when you format too - format a 15-20gb partition for the OS and use the rest for data storage, then you can just backup everything to the data partition if there are problems later and easily format the OS partition.
Old 01-10-2007, 06:40 PM
l_eclipse_l's Avatar
l_eclipse_l l_eclipse_l is offline
Your referring to the registry issues, I was talking about startup programs.
'92 3000gt SL
Zoom Stage 1 Clutch
Originally Posted by kjewer1
I disagree. Better is better. Bigger is just bigger.
I just made that up, and I like it.
Old 01-10-2007, 11:05 PM
Oh okay, thanks for the clarification. I thought when you do the backup within CCleaner, it covered all the changes you make while running that program. I didn't realize it only covered registry issues.
