Go Back   Automotive Forums Car Chat > Dodge > Dakota
Old 12-28-2006, 03:32 PM
gnemac gnemac is offline
Re: 91 5.2 will not start
Sorry to disappoint you all but no I do not have it running yet. I am in the process of doing some voltage test that you have suggested. I was just thanking you for the help you have sent.
Old 12-29-2006, 08:22 AM
rhandwor rhandwor is offline
I was thinking of another distributor. The switch plate assembly has to go over the pulse ring. When you set this in place make sure you stay on the clean marks so it is positioned identical to the one removed. Make sure the pulse ring is in good condition and didn't get bent.
With the wire disconnected in the round connector put the alignment pin an top pin 1. Put a jumper between 2 and 3 turn ignition switch to on. Using insulated pliers put the coil wire appx. 1/4 inch from ground you should have good spark. Use a volt meter and put one end in pin 1 and the other end on a ground it should be within one volt of battery voltage.
If these work out next check for a pulse when cranking with a test light.
I have gotten defective new parts ask for a replacement if no pulse.
