Old 12-19-2006, 07:30 PM
sLADe781 sLADe781 is offline
Re: clunking in front end
Linebckr49, any luck on finding the cause of the clunk? Also, did you call 3sx? What did they say??? Hehe
Old 12-19-2006, 08:35 PM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
no progress on the source of the clunk. i checked all the motor mounts with a flash light, and they all appeared fine. however, the way mitsu designed our motor mounts is strange. on some (rear, front, driver...i think) there is a small cut out portion through the rubber. i think this allows it to flex. however, it makes inspecting the integrity of the motor mount quite difficult. ususally, when a motor mount tears/rips, it begins around this hole.
i'm going to eliminate the motor mount possibility (b/c i don't have money for poly mounts forced upgrade ) right now and move on to the cv joints and brake wheel system. however, since i'm skiing right now, i'm not at home to work on the car. i got some new tires (Falken ZEIX ZE-xx), and i'll get them mounted on some stock 17" rims i picked up as payment for some work i did on a guy's 3S. when i get those mounted, i'm off for a road trip to 'Bama to visit a friend from college, then i'll visit another friend who's wedding i'm missing right now. so i won't be back in Dallas to work on my car til after the new year, at the latest.
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
