| Car Modeling Share your passion for car modeling here! Includes sub-forum for "in progress" and "completed" vehicles. |
#16
The paint looks great, and nice precision modelling! Well done!
#17
The kits differ in a couple of areas. At least on my 360 Modena coupe, the side glass, rear glass, headlight covers, and taillights were all too large and had to be sanded/scraped to fit. It was as if the entire tree was a certain percentage too big. It was a very atypical Tamiya experience! They redesigned the headlight and taillight mounting procedure on the Spider, making the headlight cover w/a small lip for mounting on the inside of the body rather than having an exposed glue joint on the edge, and the headlight buckets are separate. The taillights glue to separate mounts and mount from inside the body, whereas the coupe the taillights mounted from outside onto flat recesses in the taillight panel on the body. All clear parts, along with all the rest of the kit, fit brilliantly. |
#18
Nice paint! Can you tell me what type of paint did you use?
Thanks Andy |
#19
Top work
#20
I think with this model I finally hit on it. The silver is SnJ Spray Metal, an airbrush-only paint that's normally used for aircraft. (It's available at http://www.snjmodelproducts.com/). Unlike a lot of metallic finishes, it dries really hard -- you can handle it and mask over it without damaging it. The only problem is that it's a little dull all on its own. When it was dry, I airbrushed on a coat of Testor high-gloss clear to give the finish some shine and depth. Matt |
#21
GREAT EXAMPLE
Current Build.....1/12 Scale Camaro......Almost finished!!! ![]() ![]() View All My Models Here. |
#22
Hey! I've work with silver paints and it's always a problem, the metal flicks comes off together with masking..........and the surface is always not as smooth as i wish it to be.
I found that Tester Silver gives to best shine. How does SnJ silver compare to Tester?? You did a great job with your surface, how did you make it so smooth?? I try adding Tester Super Clear to the silver hoping it'll come out better........but still not as good as yours...... |
