Go Back   Automotive Forums Car Chat > Ford > Explorer | Explorer Sport Trac
Old 02-05-2007, 12:55 PM
trini8414 trini8414 is offline
Re: 1993 ford stalling
what could cause the truck to lose rmp ? the rmp drop low some time while driving
Old 02-05-2007, 05:47 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Are there any other symptoms, or are you just basing this on the tachometer reading in the instrument cluster? Does it only do this under certain conditions such as approaching a stop or when cruising on the highway, going uphill, etc.?
-Rod
Old 02-05-2007, 10:28 PM
-Rod
when approaching a stop and when driving at normal speed the tac drops below one less than half, someone told me that it could be the trany losing power
Old 08-30-2007, 12:30 AM
raseyroger raseyroger is offline
92 explorer acts like its running out of gas when it goes over bumps check engin lite comes on goes off as soon as it clears up
Old 08-30-2007, 12:44 PM
shorod's Avatar
SHO No Mo
Welcome to the forum!
Since your Check Engine Light (CEL) has come on, there should be stored codes. On your pre-1996 Explorer, you can read the codes yourself with a paperclip. Check out the directions at http://autorepair.about.com/cs/troub...l_dtcs_18a.htm, way at the bottom are the instructions on how to short the test connector to enable the CEL to display the codes.
-Rod
