Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 11-30-2006, 09:03 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: 1994 Caprice Motor Disaster! Please help!
Originally Posted by Musician423
why?
I dunno.....say it was time to junk the caprice, and I wanted to keep
the motor for some hot rod project. Not saying now, but say 10 years
from now when the car's rusted and pooped out.
I was just curious if the LT1 accepts old school type setups like
manifolds, dual quads, etc.
ok, gotcha. No, the LT1 (and L99) are a one-shot design, most components are not interchangeable with other (Gen I) small blocks: heads, intake, block, water pump etc. Unless there is an aftermarket for a carb'ed LT1, you can pretty much count on always running it as an LT1.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 12-04-2006, 03:37 PM
Musician423 Musician423 is offline
I will be removing oil pan from 4.3, and see that I need to detach exhaust
manifold, remove motor mount bolts, and then jack engine up. My question is how? Floor jack? Spare tire jack? Where should I position jack?
Thanks
Mark
Old 12-04-2006, 05:38 PM
silicon212's Avatar
Confoundingly Lucid
Originally Posted by rhandwor
If the engine is jacked up put a jack stand under the crank pulley
NOOOOOOOOOO.
This is DANGEROUS FOR SAFETY and damaging to the engine.
You can use a piece of wood on the floor jack to lift the engine by the oil pan, after removing the mount through bolts, and once the engine is lifted about 3-4", you place a block of 4x4 under each engine mount, between the engine and frame mounts and then lower the floor jack.
Old 12-04-2006, 09:56 PM
Thanks for the idea. I'll pick up some 4X4 scraps somewhere
Mark
