Old 12-07-2006, 08:05 AM
joe8918's Avatar
joe8918 joe8918 is offline
Re: Leaf spring replacement?
Thanks your input. That's what I was told by a guy who's pretty knowledgeable. Quadratec tech also said the same thing.
Old 12-07-2006, 11:52 AM
AlohaBra's Avatar
AlohaBra AlohaBra is offline
Cool Re: Leaf spring replacement?
Here is something else you might be interested in....to extend you shocks a little and the make the top mount sturdier.
http://www.rocky-road.com/xjbarpin.html
Old 12-12-2006, 03:40 PM
wagonbldr wagonbldr is offline
Found this website that had a good cheap option for a 4" lift. www.lunghd.com
Old 12-18-2006, 09:05 AM
joe8918's Avatar
Please bear with me...I'm almost done with this topic. I have the parts from Quadratec and need to understand something.
1.) The leaf springs come without the bushings installed. Is there any difficultly that I will experience with putting them in? I was helping my dad with some bushings for a inner tie rod on Saturday and that was a little bit of a challenge. Any tricks? We used a bolt and washers and nut to draw the bushing in. Anything easier?
2.) I heard that the front bushing attachment fastener is something you definately do not want to break because it's a weld nut with no access if it breaks. I live in MI so we have a good amout of rust possible. Should I just drench it with PB Blaster? If it breaks what do I do besides freak out?
3.) (Non-Jeep related but still a question that you experts might know) I just got a few muffler and when they installed it the bend is in such a way under the current limp spring that when the new one is on it will definately hit the tail pipe. Is there any trick I can do with heating up the muffler and kind of bend it myself? I'm assuming no but I'm just trying to save some bucks if I can. Please advise. I do not have easy access to an aceltelyne torch or anything to really put direct heat on it other than a blow torch. Plus it's really close to the gas tank so I don't want to risk a "thermal event". Please advise.
Thanks for your support so far.
-Joe
Old 12-18-2006, 10:21 AM
Ray H Ray H is offline
The bushings should be tight. I use a bench vice and assorted sockets to squeeze them in. Grease them up, they will go much easier.
2.) I heard that the front bushing attachment fastener is something you definately do not want to break because it's a weld nut with no access if it breaks. I live in MI so we have a good amout of rust possible. Should I just drench it with PB Blaster? If it breaks what do I do besides freak out??
Just dont break it. Thats the best advice. I think I would steer clear of air tools while trying to remove them. By hand you have alot better feel for what is going on. I have confidence you wont break them so Im not going to the trouble of looking up a writeup to fix it yet.
-Joe
Youve got a metal tank, as opposed to the newer plastic tanks, so I wouldnt worry about melting the tank and exploding. Just kick and push until the exhaust clears everything. If that doesnt work, take it to someone with a torch. Shouldnt take them more than a few minutes to get it done.
Old 12-19-2006, 06:45 PM
AlohaBra's Avatar
On the exhaust clearance..where is it going to hit?
You could move the hanger over or flip it. Or you can cut it off with a cutoff tool and clamp a new one in place. Or even the same one...you can take it to a muffler shop and they have a spreading tool to make it a larger diameter so that it will slip over the old part.
