Old 11-22-2006, 05:47 PM
Tony's Avatar
Tony Tony is offline
TLD Member #1
Send a message via AIM to Tony
Re: Strut bars(does cheap work)
I agree with you EF9JDM.
BamBam. I know the basics on suspensions, thats why I said I wasn't going to explain it, because I can't really. I know theories, but I can't explain it easy. I know one major thing to consider is what type of surface your gonna be going on. Dirt is completely different than asphault, so its been throwing my suspension setup off.
Speaking of spring rates BamBam, you know where to find out the stock spring rates on Civic/CRX/Del Sol's?
Tony
91 Civic Sedan DX - Stock 287k Miles
Old 11-22-2006, 06:06 PM
bambam89lx's Avatar
bambam89lx bambam89lx is offline
AF - Advisor
Send a message via AIM to bambam89lx
Not sure...honda-tech.com search is your best place for searching.
Off the top of my head I think it is 200/150 or 200/100...something like that. It's rediculously low. I mean...it's a very light car.
Jumper harnesses, mpfi conversions, engine harness conversions, vtec subharnesses, etc.
The absolute lowest prices at the absolute highest quality. Trusted. Guaranteed.
Click the image above to visit our online store!
Hastings Bseries and Dseries piston ring kits (inc. ZC) - $49 shipped
Old 11-22-2006, 11:15 PM
DogGod's Avatar
DogGod DogGod is offline
I got an Ebay strut bar, not the cheapest one, but it was cheap. I put my g-timer in and went around some corners, without the bar the highest lateral G I got was a .5 something, after I got about .9 for a split second, but can hold a .75 on clover leafs.
"Do they speak English in What!?"
Old 11-23-2006, 11:59 AM
Tony's Avatar
TLD Member #1
They are different between the models BamBam. I know the Del Sols have a lot more coils in them than the civics do, so Im assuming there are different spring rates between the models. Main thing I do know is getting the damn spring compressors on a Del Sol spring is a pain in the ass.
Tony
Old 11-23-2006, 02:01 PM
Christ Christ is offline
Send a message via AIM to Christ Send a message via Yahoo to Christ
bambam, you're right, I know jack about suspension dynamics... I didn't put the coilovers on the car.. the kid I got it from did, but he's one of my friends, that I currently live with.. either way tho, you still notice a HUGE difference over stock, simply b/c the car is lower... lower center of gravity makes it more stable, and it corners better, without rolling.. the ones he got tho, they actually made the car hella stiff before we put the strut bars on it, to the point that it stayed flat (just about) on a 60 degree corner @ 75 mph on stock tyres. you could really start feeling the tyres roll off the sides tho.. 175/70R13 (H rated?) so I'm pretty sure that with a good set of Kumho or BFG 205/40ZR16's on there, it would perform noticeably better.
Tony, if you can't get a coil into a compressor, just reinstall it in the car, put the car's weight on it, loosen the retainer nut like you normally would, take off the retainer, and slowly jack the car up to release the spring pressure... you pry already knew that, but just in case, I had to say it... I don't own spring compressors, and I don't trust most of them anyway... so I just do it that way.
