Go Back   Automotive Forums Car Chat > Pontiac > Fiero
Old 11-16-2006, 03:37 PM
hotrod_chevyz's Avatar
hotrod_chevyz hotrod_chevyz is offline
Re: 1987 2.8l sputter but not run right
Originally Posted by pontiacguy1988
I dont think I shorted anything out. And yes I have connected a scan tool and there are no codes present.
However when I first tried with the scan tool it told me that it could not connect to the ecm. So I followed all of the harness wires and found a fusable link broken right before the link, this wire was located right by that big block of wires by the battery, after fixing that it was able to comunicate to the scan tool.
Also, a bad point of fieros is the way the wires are routed near the battery. The last one i worked on wouldnt run because of burnt wire shielding. I believe the wires im talking about if memory serves me right, wiggled between pullies and all sorts of crap. Rerouting the wires could save you a lot of troubles later on down the road.
Old 11-16-2006, 09:59 PM
pontiacguy1988 pontiacguy1988 is offline
Well I know for a fact that my timing and firing order are correct. Plus out of despiration I sat there and put the order in all 6 different ways lol. But through my works I have not pulled my heads off, however if there is a burnt valve wouldnt that affect my compression? Which it was 92psi in every cylinder give or take 1psi.
And yes I know the wires you are talking about but I could not find a fault in them, I am trying to get a hold of a working wiring harness but its harder than imagined lol.
Old 11-16-2006, 10:38 PM
Yes it would.
Old 11-17-2006, 12:17 AM
Right, so since my compression is good... wouldnt that suggest that my valves are not burnt?
Old 11-17-2006, 12:32 PM
It sounds like timing to me. No matter how screwed up everything else is, you shouldnt get any backfiring unless somthing is wrong in the timing and the order of every single element involved, such as spark and the position of each valve during spark.
Maybe its time you took it to a shop andrew. Most shops will diagnose the problem free, or under 100 bucks.
Old 11-17-2006, 08:41 PM
Thats why I am on this forum because I have been to two shops and they had a 50$ fee, and found nothing. And I need to fix this car because I am not done the engine swap on my bonni and Im pretty sure my Saturn is a write off (got tboned woo hoo)
