Old 11-13-2006, 12:54 AM
SkylineUSA's Avatar
SkylineUSA SkylineUSA is offline
Send a message via AIM to SkylineUSA
Re: What's so great about a 5.0?
Originally Posted by Underground_Killah
oh no no no the block was a grand by itself, custom built. i was told after about 900hp you've gotta go with aftermarket, but still.. 900 hP!!!
900 on a stock 85 302 block? More like 450-500. There is only one block that can handle 900hp that Ford made, and that is a Boss 302. The older Mexican blocks can handle a little more than 500, but I would not push 900 through them.
R32 GTR w/351w .020 forged, 8.9:1, PTK T76, Turbosmart 40 BC & 45 WG, Tial 40 BV, AFR 205s 310/245, 228/228 550/550 114 Hydro, 1.7rr, Isky RLs, 4" HKS exhaust, ARC 30x16x4 IC, 8 point cage, C2 gauges, 2 step, C4 3200 stall w/ R Manual & Hurst Ratchet shifter, 17" Panasport G7s, CSU 750 & bonnet, Vic Jr intake, 3.63 gears, Corbeau Carrera seats, Custom wide body, Bomex side skirts and rear 1/4 caps, Tommy Kaira bumper.
Old 11-13-2006, 07:33 PM
Underground_Killah's Avatar
Underground_Killah Underground_Killah is offline
Registered User
well the guy's mustang i saw was custom... i'll get pics of it to prove... typo 500 was meant to be pushed, don't judge
Old 11-13-2006, 09:32 PM
TheStang00's Avatar
TheStang00 TheStang00 is offline
dont worry, skylineusa here is a pretty cool member. youll find that if you need help with your car, hes a good person to get it from.
Old 11-14-2006, 07:02 AM
72' Stang 351 H/O's Avatar
72' Stang 351 H/O 72' Stang 351 H/O is offline
Originally Posted by TheStang00
turn up your volume for this just in case your not sure, yes thats the original 60's version.
http://video.google.com/videoplay?do...ord+gt40&hl=en
I'm in school right now, when I get home i'll have to post up the 1969 Mustang video I have...it's sweet.
Old 11-14-2006, 07:56 PM
Registered User
i've noticed that as of late, there's some very knowledgable people on this forum... bunch of life savers i say!
Old 11-25-2006, 10:32 AM
mustangman02232 mustangman02232 is offline
Send a message via AIM to mustangman02232 Send a message via MSN to mustangman02232 Send a message via Yahoo to mustangman02232
actually the terminators can handel around 900 HP as well
the 302s not a bad motor, it just isnt the best in the ford stable
2004 F350 6.0 4x4 auto SRW
SCT X3 with innovative tunes, autometer boost/trans/pyro, AFE stage 2, MBRP 4" no muffler or cat, EGR delete, ARP studs, 8' fisher MM2, misc appearance
90 F350 7.3 IDI 4x4 SRW (sold)
bolt on 02 mustang 232 4R70W vert (sold)
built 88 toyota pickup (sold)
bolt on 92 camaro LO3 TBI (sold)
Old 11-25-2006, 01:06 PM
silverstangs's Avatar
silverstangs silverstangs is offline
Send a message via AIM to silverstangs
My factory 5.0 block can handle over 1000hp, its not my fault that everyone else use the crap ones..
You must have a factory DART block...
My ride at my site Silverstangs.
Old 11-25-2006, 01:19 PM
The only 302 blocks that I know that can handle 900~1000 are the DART blocks.. which are not made by Ford...
The most powerful 302 Crate engine from Ford tops out at around 450hp. Which is if I remember correctly a stroked 302 which is punched out to a 347..
Old 11-25-2006, 01:28 PM
351wStang's Avatar
351wStang 351wStang is offline
The mexican blocks and boss blocks are stronger than the 5.0 blocks. How much so I am not sure. For those big power numbers you need Dart/World or a R-302 block IMHO.
1969 Cougar
357w & TKO - 475hp
Old 11-25-2006, 03:49 PM
R-block is nothing more than a MARINE block, that you can yank out of any old boat with a 5.0L in it, and I have never seen a Marine or "R-block" hit 1000hp anywhere. Dart/World have much more mass than anything from Ford... But that's why you spend the big $$$$ for them compared to a Ford block.
Old 11-26-2006, 02:28 AM
SkylineUSA's Avatar
Its a seasoned Boss 302
Old 11-28-2006, 12:47 AM
351wStang's Avatar
I know of one guy who has a 302ci R-302 block in his turbo mustang and is pushing 1200rwhp.
1969 Cougar
357w & TKO - 475hp
Old 11-28-2006, 08:11 AM
I hear things like that often,
Originally Posted by person
I know a guy making XXXXhp with his car!
and
My car makes XXXhp and XXX ft-lbs of torque
all I have to say, is that I always doubt everyone untill I see a dyno.
Honestly, when people say things like that.. I have the following going thru my mind..
What dyno what is tuned on?
Who tuned it?
What turbo/blower is being used?
What injectors?
What fuel pump?
What engine?
What's in the engine? Crank/Rods/Pistons?
What's the compression ratio?
What tranny?
What clutch?
Basically, I want spec's and a dyno sheet, otherwise, it's all hearsay...
Old 11-28-2006, 10:07 AM
SkylineUSA's Avatar
I don't need dyno numbers, you can make a 50hp yugo read 1000whp if you wanted
I would perfer 1/4 times or better yet trap speed and weight of the car to make a better call on what kind of power its putting down, but like Silver I am pretty skeptical of claimed hp numbers.
Old 11-29-2006, 01:00 AM
351wStang's Avatar
I was refering to Brent from TM.com Tony. I'll try to post a link or something with his combo/dyno sheet for you silver. But he did run 162mph in the 1/4 and had to throttle it twice because he started spinning. I think his car is around 3100lbs.
Basically he has a 302ci R block with I think High Port heads xcelerator intake, f303 (beleive it or not), Eagle 4340 cranks and rods with I beleive JE pistons. Then of course there is the majestic 88mm turbo pushing around 30psi. As far as the tranny goes he is now runing a glide. MF500 pump, Aeromotive 13202 reg, CSU 850 holley... He's making the number.
1969 Cougar
357w & TKO - 475hp
