Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 05-22-2010, 11:22 AM
ifixthings ifixthings is offline
Re: 1989 Camry Shift issue
Originally Posted by Mike Gerber View Post
I'm no trans expert but a few questions come to mind. How many miles are on this car? How old is the trans fluid that is in there? What color is it?
Mike
close to 240k miles. and i have no idea how old the trans fluid is. and i wanna say its a goldish(?) looking color. i've been to autozone and asked them about it and the guy said the bands might need to be tightened. but i'll try flushing and refilling the trans first to see if that corrects the problem.
Old 05-22-2010, 03:08 PM
Mike Gerber Mike Gerber is offline
AF -Advisor
"i'll try flushing and refilling the trans first to see if that corrects the problem."
Draining and refilling the transmission through the drain plug in the bottom of the pan (if that's what you meant) (you actually refill through the dipstick hole) only drains about 1/3 of the transmission fluid. You might want to try one of the places that uses a machine hooked up to your transmission and drains and refills about 99% of the fluid. Or you could drain and refill the fluid using the drain plug, a number of times after driving a few hundred miles each time. That and keep your fingers crossed. 240,000 miles is a lot of miles, especially not knowing when the fluid has been previously changed.
Good luck.
Mike
Old 05-22-2010, 04:18 PM
Smile Re: 1989 Camry Shift issue
Good luck.
Mike
for close to 240k it still runs like a dream, aside from the transmission lol. its a crust bucket buts its a tough crust bucket. ill ask around some more and see if i can find a trans shop that'll diagnose it. thanks mike. ill keep ya'll updated.
Old 06-08-2010, 02:23 AM
270+camry 270+camry is offline
To dobb, i'd tell you to check to see if ur TCM is throwing any codes and also ur transmission solenoids, they can be cleaned sometimes and that can do a world of good. They aren't cheap. sorry that was 3 years late but id put money on that it's solenoids.
to ifixthings, it serisously always helps to clean the solenoids bro, or at least doesnt hurt. topping off the tranny fluid wont always help if u got a nasty fluid and a stopped up filter. Mike is right, doing the tree shade fluid job wont change all the fluid out, but at the same time it beats the hell out of 160 bucks to get it flushed. i say pull the trans pan off, drain it, check the solenoids since i think in that car they are inside the pan (on some cars they bolt to the outside, my car is manual so i cant tell you.) also check to see if ur trans is throwin off any codes, i think its behind the glove box, hopefuly someone chimes in an tells u the exact location of these things but im sure you can google it. when u get all that done and have changed the filter and gasket, drive for like 100 miles to let the fluid cycle into the torque converter and then flush it again. the fluid and all ain't cheap if you are on a budget but it's worth the preventive maintenance.
question, does ur engine run hot? hot engine means hot trans and hot trans shift like dog crap.
Old 06-08-2010, 11:13 AM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
It is recommended that you NOT have the transmission power flushed at this point at a shop. Any varnish and build-up that has formed inside can break loose during the flush and re-deposit inside the valve body and cause a total failure. Do as suggested with a fluid drain and replace the filter inside the pan. Run it a few hundred miles then drain and refill again. Repeat drive, drain, and refill again. This allows the gunk to be slowly redissolved.
You might consider adding some transmission fix such as Lucas Oil (don't overfill) to the last refill. Use only the amount as directed. It's a thicker fluid that helps older valve body seals maintain pressures. I have not read or heard of anyone else having issues with this stuff, but I have used it successfully (so far) in my old Chevy truck.
Hope this helps!
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
