| Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible. |
#16
Re: Clutch assembly or transmission?
The TOB would ONLY make noise when you have the clutch disengaged(pedel pushed in) if it only makes noise when the clutch is engaged that rules that out. If I understand your problem correctly the noise happens at idle with your foot off of the clutch correct? If that be the case its most likely the input shaft bearing.
2004 Flame Red SRT-4 |Audiobahn 1200Q|Rockford 602s|Jensen flip out dvd| Mods: ![]() |
#17
Hmm....I guess that could be....and yes you are correct...It makes a noise at idle when the clutch pedal is not pressed in....but the the noise gets much louder while the car is in gear and under load....does that sound like it could be the same thing....or do you think that might be a whole other problem completly?
1998 Eclipse GSX 6 Bolt swap MHI Big 16g FP Race Manifold Apex'i N1 Cat-back Apex'i N1 Downpipe Walbro 255 fuel pump GReddy Type S BOV Turbo XS Boost Controller Balance Shaft Elimininator ACT 2600 RRE 11lb No Name Flywheel Prothane Motor Mounts Tokico Illuminas Advanced Handling Kit RRE Front and Rear strut tower bars RMDSM Front and Rear Sway Bars TRE Stage 2 Tranny ARP Head Studs, Main Studs, Rod bolts |
#18
The noise your hearing at idle and the noise under load are most likely the same noise. And you're most likely going to have to pull the tranny and do some diagnosis. Good luck man.
#19
I second the input shaft bearing idea. I just finished 2 5-speeds, one from a geo, one from a ranger. Both had the same symptoms and both spit the input bearing rollers at me when I dis-assembled them. The geo transmission had a rear mainshaft bearing out, too.
2007 Certified DaimlerChrysler Service Technician... True blue GM at heart. |
#20
sorry i had to...
![]() i hate people who think they know everything.. answer the damn question and move on.... post what you think it could be... sounds like a throw out bearing to me... but i could be wrong.. |
#21
Awesome guys....thanks for all the ideas....I knew I was going to have to take it all apart to figure it out but I just wanted to get some ideas before I jump in there....if you can think of anything else that would be great too...
#22
I'm pretty much 100% sure its the input shaft bearing
#23
to replace that, IIRC, you'll have to disassemble the tranny, correct?
1991 Eagle Talon TSI - Broken Head removed, block broken, trans in hatch ![]() 1991 Eagle Talon TSI AWD- in pieces 3" exhaust, rebuilt bottom end Project: Assemble the Eagle is underway... and now with AWD 2003 Lancer Evo 1630hp/1593ft lb tq |
#24
I shouldn't answer for fear I may make someone "dumber", but usually yes. Even if you don't have to, it's always a good idea to inspect all the internals just in case some bearing parts decided to fall inside.
#25
you have to take the whole thing apart. Its not bad if you know what you are doing
#26
I have a friend that builds transmissions for a living....so he is going to help me out....
#27
you should have no trouble then
#28
^Lucky Bastard (no offence, just a saying of mine)...
I'm envious... I just bought a tranny and it is cracked on the end. I am gonna swap my cap for that one, but I didn't wanna have to do that... I will probably have to end up swapping internals...
