| Engineering/ Technical Ask technical questions about cars. Do you know how a car engine works? |
#16
Re: Driveline vibration.
If all else fails make sure the U joints are in time on the 2 piece drivelines.
If not you will get some strange shaking. Good Luck Mt
#17
have you tried raising the car off the ground and running it up to 60mph and narrowing it down that way?
Don't really suggest this on jack stands. Car lifts are handy for this kinda thing. Thats how we find most of our problems of this nature....assuming its reproducable with no load. Sometimes they aren't
life begins at 10psi of boost Three turbo'd motorcycles and counting.
#18
Seatbelts Saved My Life
#19
For the real hard to find viberations the hunter GSP-9700 is one of the best.
It spins them on the car at road speed. It will almost balance a square wheel. For the nearest one. http://www.gsp9700.com/pub/search/FindGSP9700.cfm
#20
#21
We have a on-the-wheel balancer from the 70's at work that the owner (old fart) pulls out now and then to get an old car "just right". Never see need for it on modern stuff. And it will only help you if the problem is at the hub assembly. A bad u-joint, drive line, etc, wouldn't do you a bit of good
#22
That is why I posted the link. Most 50-60 mph vibrations point to wheel balance problems. quote from the first post on problem. This car has a driveline vibration noticable in 4th and 5th gear at any speed over 40 mph. it is quite mild except between 50 to 60 mph. At 50-60 it gets worse, (a moderate vibration) and smooths out somewhat over 60, but is still noticable. It is noticably worse in 5th gear than 4th. It's pretty uniform whether I am on the gas or coasting. Also, it shakes even when I shift to neutral at that speed.
